skurakai
Posts: 3 Joined: 2008-09-18 15:07:16
Post
by skurakai » 2010-05-16 12:47:16
Hi. I'am using AMC for some years.
I like this but sometimes i need edit more than one item.
It would by fine edit more than one films simultaneously.
Eg. i need edit 10 films and add same director for all films. But there is no editation after multi-marking
Thanks for consideration
skurakai
Posts: 1148 Joined: 2006-12-11 22:54:46
Post
by bad4u » 2010-05-16 22:12:33
Editing multiple movies can be done by scripting, though it is not that comfortable.
Posts: 9869 Joined: 2002-05-30 10:13:07
Post
by antp » 2010-05-17 11:17:49
There is an "update fields" script (available from scripting windows, shift+F6 or tools menu) which makes some of the changes a little easier than by writing a script yourself.
moskittiero
Posts: 14 Joined: 2006-06-23 10:25:28
Post
by moskittiero » 2010-05-19 10:25:37
I agree with skurakai - doing the same change in multi selection should be allowed.
Posts: 785 Joined: 2007-04-28 05:46:43
Post
by fulvio53s03 » 2011-05-21 05:42:45
moskittiero wrote: I agree with skurakai - doing the same change in multi selection should be allowed.
... and it is allowed! Read ANTP preceeding answer:
1) select movies to edit
2) use "update Fields" script
3).... et voilà!
