adding movies by scanning HDD for specific file extensions
rob-l
Post by rob-l »
Is it possible to add movies to the database by scanning hard drives, and more specifically scanning network drives, for files with certain extensions.
For Example:
I want to scan "\\pc2\movies1" for files with the extensions .iso, .img, and .avi and then automatically add those files to the movie database, using the filename as the title.
Is this possible with ANTP Moviedb?
There is another program that has this feature called Movie Label 2011, but it takes way too long to scan for files on network drives
All known solutions are listed on that topic: viewtopic.php?t=229
