Is there a way to batch add data into fields? For example, I have different racks of movies and would like to put into a field maybe the 'source' field?) "rack 1, rack 2", etc. to show the location of that particular movie. However, it appears I'll have to do this one movie at a time. I'd like to be able to select a group of movies, and type my entry in ONCE and have it populate that same field for every movie. Is this possible, and I'm just overlooking something obvious?
Thanks much!
Batch field entry?
You can do that with scripting.
Run it on all movies or only selected once and it will fill field source with what is stored in value. Be sure to make a backup of your movie database before you try to modifiy it with scripts
program NewScript;
value = 'Rack1';
setField(fieldSource, value);
the_observer
Hi all.
In continuation of the previous useful post this is what i try to do.
I use Media Type field to store in which Hard Disk i keep my movies.
Now i have bought a disk and changed the location of the movies.
With the above instructions i have concluded that i should make and run the below script with the movies i select :
The problem is that when i press F6 i dont see the above script (named MassReplace)
I bet it is something easy but i just cannot find it
Any suggestions?
Thank you 4 your time reading this.
Regards,
The_Observer
P.S. The first time i tried this i had the same problem.So i changed the name inside to be identical with the file name and this seemed to work since then i was able to see the script (although it was greyd out).Probably it was not the cause because again the script is not showing.
Then i thought it should be from language filter show i pressed the "Check All" button.Well it appeared once.Next time i pressed F6 it was not there again.Really weird.
program MassReplace;
value = 'NewValue';
setField(fieldMedia Type, value);
end. I bet it is something easy but i just cannot find it
Any suggestions?
Regards,
The_Observer
program MassReplace;Then i thought it should be from language filter show i pressed the "Check All" button.Well it appeared once.Next time i pressed F6 it was not there again.Really weird.
the_observer
Ok fixed.
The problem was that i was pressing F6 to see scripts while i should press Shift+F6 (show it from menu)
Although now i have a new problem.
When i run the script it says :
Error in expression at line 5
My humble opinion cause i dont know much of programming is that should be the space between fieldMedia Type because when i tried the script with another field ,one with only one word and no space inbetween it worked (c.c. fieldSource)
Any suggestions please?
Regards,
The_Observer
Regards,
The_Observer
the_observer
Just a note on that: F6 (or the button "get information from internet") only shows scripts that have script option "get information from internet" set "True". You can find that option on script editor, when you hit preferences button there.the_observer wrote:Ok fixed.
the_observer
