MPAA Rating
Archange
MPAA Rating
Post by Archange »
Hi all, I have installed the dynamic template, everything is working great. I need help with customizing. I saw, in your demo page, that you can see the MPAA Rating (G, PG-13, PG, R). I want to display that on my page. How can I do that ? in my AMC program, I don't have a section for this.
Second, in AMC, the "Category" section with the dropdown menu selection. I want to delete some of the categories and/or change there names. How can I do that ?
Thanks for the help...I love AMC !! :)
Re: MPAA Rating
Archange wrote:Hi all, I have installed the dynamic template, everything is working great. I need help with customizing. I saw, in your demo page, that you can see the MPAA Rating (G, PG-13, PG, R). I want to display that on my page. How can I do that ? in my AMC program, I don't have a section for this.
For the first part of your question please read my answer on the other thread: viewtopic.php?t=4600
To delete some of the dropdown options from categories field, you should simply need to delete the specific options from all movies, it should disappear if I remember correct. To do this group your catalog by categories and you will see which movies are in that specific ones.
If it doesn't help, go to Tools -> Preferences -> Movie information -> DropDown lists and check options for list categories (try deselecting "use values of current catalog", saving and enabling again).
Archange
Post by Archange »
OK for the first part, I sent a reply with question to the person cause I don't fully understand yet.
second part is ok. What I did is to add my own ones for the category fields...so I see only mine.
Merci....Thanks I will now try to retreive those mpaa infos tsssss :P
Just a note: If you have questions on a specific template, you better ask on the specific forum thread where you downloaded it from, so that the template designer gets an email notification for the new post and might help you better than I can ;)
Archange
Post by Archange »
yes I know but no one was answering so I tried with you. Sorry again. I'm new here and also french guy :P I try to understand everything.
Thanks.
Dedej
MPAA rating
Post by Dedej »
Sur quelle version du template est tu la "Template_v2.2.2_from_Bergware" ou c'est un autre template? Et en version anglaise ou française?
Archange
Post by Archange »
2.22 oui mais j'ai résolu l'affaire dans l'autre thread désolé je débute sur le forum. Je m'adresse pas au bon endroit :P
Merci.
