Field Summary Help
MrGer
Field Summary Help
Post by MrGer »
Hello!
I'd like to summarize 2 field, but it doesn't working....
I try these (in the AMCReport designer, Field Text Editor / Script option:
1. create a new field, set datatype to number and create a script:
Sum([label:Size]), Sum([label:Disks])
2.
Sum([Size], MasterData), Sum([Size] + [Disks])
I put this filed on MasterData or PageFooter.
I get an Error Message all time...
(And also like hide expression, when it appeared twice. e.g. make a list, when I sort films as Director, but one director can visible just once.)
Can anybody help me?
I am not sure that master/detail is supposed to work, it is rather for real database sources.
I do not know what Sum is supposed to do either.
I use a complete reporting engine, but only some of its feature are available in the way I use it in AMC.
MrGer
Sum
Post by MrGer »
Thanks! I'll try again...
