Script for Cinemacomrapadura.com.br
cluis_henrique
Post by cluis_henrique »
Authors=Luis Henrique Carneiro
Title=Cinemacomrapadura
Description=Movie importation script for Cinemacomrapadura
Site=http://cinemacomrapadura.com.br
Language=BR
Version=1.0 (19 Março 2010)
Requires=3.5.1
Comments=
License=This program is free software; you can redistribute it and/or modify it under the  terms of the GNU General Public License as published by the Free Software Foundation;  either version 2 of the License, or (at your option) any later version.
Link do site Oficial=0|0|0=Não|1=Sim
program Cinemacomrapadura;
uses StringUtils1,StringUtils7552;
var nomeFilme: string;
// simple string procedures
function ra(S : string) : string;
Begin
  S:=StringReplaceAll(S,'ç','c');
  S:=StringReplaceAll(S,'ã','a');
  S:=StringReplaceAll(S,'é','e');
  S:=StringReplaceAll(S,'í','i');
  S:=StringReplaceAll(S,'Ã','a');
  S:=StringReplaceAll(S,'“','"');
  S:=StringReplaceAll(S,'â€','"');
  S:=StringReplaceAll(S,'acute;','');
  S:=StringReplaceAll(S,'tilde;','');
  S:=StringReplaceAll(S,'cedil;','');
  S:=StringReplaceAll(S,'&','');
  S:=StringReplaceAll(S,'aª','ê');
  S:=StringReplaceAll(S,'a¢','â');
  S:=StringReplaceAll(S,'a¼','u');
  S:=StringReplaceAll(S,'a¡','á');
  S:=StringReplaceAll(S,'','');
  S:=StringReplaceAll(S,'a³','ó');
  S:=StringReplaceAll(S,'aµ','õ');
  Result := S;
End;
 while Pos(Old, S) > 0 do
 Result := S;
Function ConvertNum(s: string) : string;
s2, ch: string;
    s := AnsiLowerCase(s);
    s2 := '';
    For i := 1 To Length(s) do
      ch := copy(s, i, 1);
      if ((ch >= '0') and (ch <= '9')) then
        s2 := s2 + ch;
    result := s2;
// Loads and analyses page from internet
 if Pos('<h4 class="block_title filmes_title">Filmes</h4>', Page.Text) = 0 then
 ShowMessage('Nothing found.');
 Exit;
 PickTreeAdd('Search results:', '');
 AddMoviesTitles(Page);
     AnalyzeMoviePage(Address);
procedure AnalyzeMoviePage(Address: String);
  LineNr, BeginPos: integer;
  value, value2: string;
  value:=Address;
  SetField(fieldURL, value );
  value:=TextBetween(Page.Text,'<title>','/title>');
  value:=RA(TextBetween(value,'»  ','<'));
  SetField(fieldTranslatedTitle, value);
  value:=TextBetween(Page.Text,'<meta name="description" content="',',');
  SetField(fieldOriginalTitle, trim(value));
  value:=TextBetween(Page.Text,'<meta name="description" content="','>');
  value:=TextBetween(value,', ','" /');
  SetField(fieldYear, trim(value));
  value:=TextBetween(Page.Text,'<dt>Origem:','</dd>');
  value:=TextBetween(value,'<dd>','<');
  SetField(fieldCountry, trim(value));
  value:=TextBetween(Page.Text,'nero: </dt>','</dd>');
  value:=ra(value);
  SetField(fieldCategory, trim(value));
  value:=TextBetween(Page.Text,'<dt>Dura','</dd>');
  value:=ConvertNum(value);
  SetField(fieldLength,trim(value));
  value:=TextBetween(Page.Text,'dio: </dt>','</dd>');
  SetField(fieldProducer, FullTrim(value));
  value:=TextBetween(Page.Text,'<dt>Dire','</dd>');
  value:=RA(TextBetween(value,'">','<'));
  SetField(fieldDirector, trim(value));
  value:=TextBetween(Page.Text,'>Elenco</h4>','ticas');
  value:=FormatText2(value);
  value:=ra(value);
  SetField(fieldActors, value);
  value:=TextBetween(Page.Text,'<div class="sinopse">','</div>');
  value:=ra(FormatText2(value));
  SetField(fieldDescription, value);
  value:=TextBetween(Page.Text,'rios</h3>','<div class="navigation">');
  SetField(fieldComments, value);
  value:=TextBetween(Page.Text,'> - Nota','/');
  SetField(fieldRating, value);
  value:=TextBetween(Page.Text,'http://cinemacomrapadura.com.br/filmes/poster/','.jpg');
  value:='http://cinemacomrapadura.com.br/filmes/poster/' + value + '.jpg';
  if (value <> '') and CanSetPicture then GetPicture(value);
  GetPicture(value);
  SetField(fieldMediaType,'DVD');
procedure AddMoviesTitles(ResultsPage: TStringList);
 Page: string;
 MovieTitle, MovieAddress : String;
 Page := ResultsPage.Text;
 CutBefore(Page, '<h4 class="block_title filmes_title">Filmes</h4>');
 while Pos('<em>', Page) > 0 do
 MovieAddress := TextBetween(Page, '<a href="', '" rel=');
 MovieTitle := TextBetween(Page, '<em>(', ')</em>');
 MovieTitle := ra(MovieTitle);
 CutAfter(Page, '</em>');
  PickListClear;
  nomeFilme := GetField(fieldTranslatedTitle);
  if (length(nomeFilme)=0) then
    nomeFilme := GetField(fieldOriginalTitle);
  if Input('Importar do Cinemacomrapadura', 'Escreve o nome do filme:', nomeFilme) then
    nomeFilme:=stringreplace(nomeFilme,' ','+');
    AnalyzePage('http://cinemacomrapadura.com.br/?s='+nomeFilme);
Thanks, but what is the purpose of that "Ra" fonction at the top?
It seems that most of what it does could be done by htmldecode & utf8decode functions.
I am not sure either that all characters are properly kept in copy/paste.
cluis_henrique
antp wrote:Thanks, but what is the purpose of that "Ra" fonction at the top?
Is used to Remove the Accents in Portuguese.
htmldecode not attend this function fully.
The characters are OK after copy / paste again.
the good is not here in the forum.
In an editor is 100%.
Thanks!
from what seems to do the function, htmldecode alone is not enough, but utf8decode will do what htmldecode does not (but utf8decode must be used before htmldecode)
why remove accents? isn't it better to convert them properly and keep them?
