I have been using your program for about 5 years with no problems but today I used IMBD (as usual) to get movie info and the reply I get is "No movie found". This happens no matter which movie I search for.
Thanks.
P.S. I downloaded latest version, same problem.
Help - Problem loading movie info
Make sure you really use latest script version 3.59 - this problem was solved with that version. Check version number on scripting window (click on the script and see version in the info box below the list). If it shows an older version it might load an previous script version from VirtualFolder.
If you are using Vista or Win7 with UAC (User Account Control) I recommend using script [Update Scripts] to download latest updates, as it will automatically overwrite older script versions on your VirtualFolder.
If you prefer manually updating the scripts to program's folder you will have to make sure that there is no older script version on your hidden VirtualFolder, as Windows will access files from this location first.
domaversa
as bad4u said, just run the script named "update scripts"domaversa wrote: How do I update it to 3.59?
Alternatively you can get the new script from http://update.antp.be/amc/scripts/
