pippo_473
Posts: 6 Joined: 2007-04-06 08:31:09
Post
by pippo_473 » 2010-03-07 16:59:39
I have update the script for cinematografo.it.
List of changes:
FIX:script now catch the entire comments field
FIX:Correct the bug when the actor's name contains the )
You can find the script at:
http://rapidshare.com/files/360251335/C ... _.ifs.html
Posts: 9902 Joined: 2002-05-30 10:13:07
Post
by antp » 2010-03-08 20:54:36
Thanks.
But your script still has the same number as the previous one:
Version=1.13 - 06.01.2010 - SM
Is it still the right one? (contents seem different, so I guess it is and that you just forgot to update the properties)
pippo_473
Post
by pippo_473 » 2010-03-09 05:24:22
Yes, i have forgot update properties.
smb
Posts: 3 Joined: 2009-09-08 15:15:08
Post
by smb » 2010-05-16 19:11:02
Cant download: some type of rapidshare limit's reached... can you upload somewhere?
Post
by antp » 2010-05-17 11:16:22
You can get it by running "update scripts" script or from
http://update.antp.be/amc/scripts/
