[REL] FilmAffinity (ES): re-reviewed version (March 6, 2010)
aviloria
Post by aviloria »
Hola a todos,
Disculpad las molestias y la tardanza en responder a vuestras cuestiones, pero en FilmAffinity llevan haciendo cambios toda la semana y he preferido esperar un poco para no saturaros de versiones todos los días.
Aquí os dejo la última versión, donde se corrige el tema de las críticas (en muchos casos solo se obtenía la primera) y alguna otra corrección menor.
Disfrutadla!
Hi all,
Sorry for the inconvenience and the late to reply all your comments, but in the past days FilmAffinity was making changes in the site and I preferred to delay this release to avoid fulfill your patience.
Here you can have the latest version, where I have fixed critics issues (some times ony the first review can be fetched) and other minor changes.
Enjoy it!
Authors=aviloria  (aviloria@yahoo.com) modded by: rodpedja (rodpedja@gmail.com), kreti (bisoft@hotmail.com), MrK, gilistico
Title=FilmAffinity (ES)
Language=ES
Version=2.49
Requires=3.5.0
Comments=Updated: Script option for batch running (default disabled), and now it gets the category.
program FilmAffinity;
   BaseURL1 = 'http://www.filmaffinity.com';
   MovieURL: string;
   Result := -1;
   if StartAt < 0 then
      StartAt := 0;
         Result := i;
   InitialPos: Integer;
   if InitialPos = 0 then
      result := ''
      InitialPos := Pos(EndTag, S);
         result := S
         result := Copy(S, 1, InitialPos - 1);
         Delete(S, 1, InitialPos + 1);
   n, len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      // quitamos los tabuladores
      if c = #9 then c := ' ';
      if tag = 1 then
         if c = '>' then tag := 0;
         continue;
         if c = '<' then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   Line,Line2: string;
   Count: Integer;
   Count := 0;
   Page  := TStringList.Create;
   // Veamos si solo hay un solo resultado
   LineNr := FindLine('<b>1 resultados.</b>', Page, 0);
   if LineNr <> -1 then
      Line         := Page.GetString(LineNr + 7);
      Line2        := Line;
      MovieAddress := TextBetween(Line, '<b><a href="', '">');
      MovieTitle   := TextBetween(Line2, '.html">', '</td>');
      HTMLDecode(MovieTitle);
      DeleteTags(MovieTitle);
      if (MovieAddress <> '') AND (MovieTitle <> '') then
         MovieAddress := BaseURL1 + MovieAddress;
           if PickTreeExec(MovieAddress) then
              AnalyzeMoviePage(MovieAddress);
         if GetOption('DontAsk') = 1 then
   // Veamos cuantos resultados se han encontrado
   LineNr := FindLine('resultados.</b></td></tr>', Page, 0);
      Line  := Page.GetString(LineNr);
      Count := StrToInt(TextBetween(Line, '<b>', ' resultados.</b>'), 0);
   // Si no hemos encontrado ningún resultado, abandonamos
   if Count = 0 then
      ShowMessage('No se ha encontrado ningún registro');
   LineNr := 0;
   while TRUE do
      LineNr := FindLine('<b><a href="', Page, LineNr + 1);
      if LineNr = -1 then
         LineNr := FindLine('<b>siguientes >></b>', Page,0);
         if LineNr = -1 then
            break;
         Address   := TextBetween(Line, '<a href="', '">');
         LineNr    := 0;
         continue;
      Line2        := Line;
         PickTreeAdd(MovieTitle, BaseURL1 + MovieAddress);
      AnalyzeMoviePage(Address);
   Item: string;
   Comments: string;
   Actors: string;
   Directors: string;
   Comments := '';
   Actors := '';
   // URL
   // Translated Title
   LineNr := FindLine('<div style="margin-bottom: 4; padding:1; text-align: left; border-bottom: 1px solid #990000;"><span style="color:#990000; font-size:16; font-weight: bold;">', Page, 0);
   Item := TextBetween(Line, ' border="0"> ', '</span>');
   HTMLDecode(Item);
   SetField(fieldTranslatedTitle, Trim(Item));
   // Original Title
   LineNr := FindLine('<b>TÍTULO ORIGINAL</b>', Page, LineNr);
      Item := TextBetween(Line, '<td ><b>', '</b></td>');
      HTMLDecode(Item);
      SetField(fieldOriginalTitle, Trim(Item));
   // Year
   LineNr := FindLine('<b>AÑO</b>', Page, LineNr);
      Item := TextBetween(Line, '<td >', '</td>');
      HTMLDecode(Item);
      SetField(fieldYear, Trim(Item));
   // Length
   LineNr := FindLine('<b>DURACIÓN</b>', Page, LineNr);
      Item := TextBetween(Line, '<td>', ' min.</td>');
      HTMLDecode(Item);
      SetField(fieldLength, Trim(Item));
   // Country
   LineNr := FindLine('<b>PAÍS</b>', Page, LineNr);
      Item := TextBetween(Line, 'title="', '" border');
      HTMLDecode(Item);
      SetField(fieldCountry, Trim(Item));
   // Director
   LineNr := FindLine('<b>DIRECTOR</b>', Page, LineNr);
      Directors := '';
      while Pos('stype=director', Line) > 0 do
         Item := TextBetween(Line, '">', '</a>');
         HTMLDecode(Item);
         if Directors = '' then
            Directors := Item
            Directors := Directors + ', ' + Item;
      SetField(fieldDirector, Trim(Directors));
   // Script writer
   LineNr := FindLine('<b>GUIÓN</b>', Page, LineNr);
      Comments := Comments + 'Guión: ' + Item + #13#10 + #13#10;
   // Composer
   LineNr := FindLine('<b>MÚSICA</b>', Page, LineNr);
      Comments := Comments + 'Música: ' + Item + #13#10 + #13#10;
   // Photography
   LineNr := FindLine('<b>FOTOGRAFÍA</b', Page, LineNr);
      Comments := Comments + 'Fotografía: ' + Item + #13#10 + #13#10;
   // Actors
   LineNr := FindLine('<b>REPARTO</b>', Page, LineNr);
     Line := '';
     while TRUE do
        LineNR := LineNR + 1;
        Line   := Line + Page.GetString(LineNr);
        if Pos('</td>', Line) > 0 then
           break;
     Actors := TextBetween(Line, '">', '</a>') + #13#10;
     while Pos('stype=cast', Line) > 0 do
        Actors := Actors + TextBetween(Line, '"> ', '</a>') + #13#10;
     HTMLDecode(Actors);
     SetField(fieldActors, Actors);
   // Productor
   LineNr := FindLine('<b>PRODUCTORA</b>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldProducer, Trim(Item));
   // Official Webpage
   LineNr := FindLine('<b>WEB OFICIAL</b>', Page, LineNr);
      Comments := Comments + 'Web oficial: ' + TextBetween(Line, '<a href="', '" target="_blank">') + #13#10 + #13#10;
   // Awards
   LineNr := FindLine('<b>PREMIOS</b>', Page, LineNr);
      LineNr   := LineNr + 1;
      while Pos('<a href="/es/awards.php', Line) > 0 do
        Item := DeleteTags(Line);
        Comments := Comments + '  - ' + Trim(Item) + #13#10;
   // Category
   LineNr := FindLine('<b>GÉNERO</b>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldCategory, Trim(Item));
   // Synopsis
   LineNr := FindLine('<b>SINOPSIS</b>', Page, LineNr);
      Item := TextBetween(Line, '<td>', '</td>');
      HTMLDecode(Item);
      SetField(fieldDescription, Trim(Item));
   // Critic
   LineNr := FindLine('<b>CRÍTICAS</b>', Page, LineNr);
      Comments := Comments + 'Críticas: ' + #13#10;
      LineNr := LineNr + 3;
      Item := Page.GetString(LineNr);
      while Pos ('</tr>', Item) = 0 do
         while Pos('<br>', Item) <> 0 do
            Item := StringReplace(Item, '<br>', #13#10);
         while Pos('</br>', Item) <> 0 do
            Item := StringReplace(Item, '</br>', #13#10);
         while Pos('  ', Item) <> 0 do
            Item := StringReplace(Item, '  ', ' ');
         Comments := Comments + DeleteTags(Item);
   // Picture
   LineNr := FindLine('http://pics.filmaffinity.com/', Page, LineNr);
      Item := TextBetween(Line, '<a class="lightbox" href="', '"');
      if Length(Item) = 0 then
         Item := TextBetween(Line, '<img src="', '"');
      GetPicture(Item);
   // Rating
   LineNr := FindLine('<td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', Page, LineNr);
      Item := TextBetween(Line, '<td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', '</td>');
      HTMLDecode(Item);
      SetField(fieldRating, Item);
   HTMLDecode(Comments);
   if (CheckVersion(3,5,0) = FALSE) then
      AnalyzeMoviePage(MovieName)
      AnalyzePage(BaseURL1 +'/es/search.php?stext=' + UrlEncode(MovieName)  + '&stype=Title');
genoma
Trailers
Post by genoma »
Hola que tal.
Queria saber si existe la posivilidad de traer la direccion del trailer. y pegarlo en en campo fuente?
Gracias.
