All actors via IMDb
mortenl
All actors via IMDb
Post by mortenl »
Hi Ant Forum,
When I use de glorious ANT program, I mostly use the script that fetches data from IMDb. And I want to ask how to modify that script so that all the registered actors in the given movie are included in the download stream. As it is now I just get the actors that are mentioned on the first page of the IMDb site, and very often it is not the most important or prominent actors from the movie.
Morten Levy, Denmark
On scripting window click on the IMDB script so that it is marked blue. On the right side of the window you will find a list with script options now. Change option "AllActors" from 0 to 1 and it will import all possible actors.
