Duplicate, clone more than one film at a time
orl_fur
Post by orl_fur »
Hello! I was wondering if there was a way to clone / duplicate more then one film at a time.
If it's only a film it is easy and straightforward to copy /add new / paste, but I have the need to do it for a large number of films.
Thank you all in advance for your help :)
Re: Duplicate, clone more than one film at a time
One way to achieve that would be to use File -> Import, and from there you can import another catalog in the current one, but you can select the same catalog for that.
orl_fur
Post by orl_fur »
That did it, great tip and indeed very good function! Thanks a lot, great software always loved for many many years :)
