File Extension Filtering
Skelyos
Post by Skelyos »
How can I filter out the .db file extension that windows creates. Renamer is renaming the .db files as in thumbnail database image database so on and so forth.
That's one of the things I should add as feature, currently nothing is done for that :/
When making the program I did not think of that: since I do not use Windows Explorer I do not have thumbs.db files in my folders.
Skelyos
Post by Skelyos »
[quote="antp"]That's one of the things I should add as feature, currently nothing is done for that :/
When making the program I did not think of that: since I do not use Windows Explorer I do not have thumbs.db files in my folders.[/quote
Thank you for the reply and yes it would be nice as well as an right click rename from here sub menu. We use multiple OS's.
Thanks for taking the time to reply wish all software makers had your attitude. *S*
You mean something to send files to Ant Renamer, directly from the right click menu?
You can do that for one folder, by putting a shortcut to Ant Renamer in the "send to" folder, but it will open a new instance of the program for each folder you send to it.
