adorocinema.com
cluis_henrique
adorocinema.com
Post by cluis_henrique »
I made a script for adorocinema.com please test and comment.
Authors=Luis Henrique Carneiro
Title=AdoroCinema
Description=Movie importation script for AdoroCinema
Site=www.adorocinema.com
Language=BR
Version=1.0 (27 Janeiro 2010)
Requires=3.5.1
Comments=
License=This program is free software; you can redistribute it and/or modify it under the  terms of the GNU General Public License as published by the Free Software Foundation;  either version 2 of the License, or (at your option) any later version.
Link do site Oficial=0|0|0=Não|1=Sim
program AdoroCinema;
uses StringUtils1,StringUtils7552;
var nomeFilme: string;
// simple string procedures
function ra(S : string) : string;
Begin
  S:=StringReplaceAll(S,'ç','c');
  S:=StringReplaceAll(S,'ã','a');
  S:=StringReplaceAll(S,'é','e');
  S:=StringReplaceAll(S,'í','i');
  S:=StringReplaceAll(S,'acute;','');
  S:=StringReplaceAll(S,'tilde;','');
  S:=StringReplaceAll(S,'cedil;','');
  S:=StringReplaceAll(S,'&','');
  Result := S;
End;
 while Pos(Old, S) > 0 do
 Result := S;
Function ConvertNum(s: string) : string;
s2, ch: string;
    s := AnsiLowerCase(s);
    s2 := '';
    For i := 1 To Length(s) do
      ch := copy(s, i, 1);
      if ((ch >= '0') and (ch <= '9')) then
        s2 := s2 + ch;
    result := s2;
// Loads and analyses page from internet
 if Pos('>nome original:<', Page.Text) = 0 then
 ShowMessage('Nothing found.');
 Exit;
 PickTreeAdd('Search results:', '');
 AddMoviesTitles(Page);
     AnalyzeMoviePage(Address);
procedure AnalyzeMoviePage(Address: String);
  LineNr, BeginPos: integer;
  value, value2: string;
  value2:=Address;
  value:=TextBetween(Page.Text,'site oficial</strong>:<a href="','" ');
  SetField(fieldURL, value + '     (' + value2 + ')' );
  value:=ra(TextBetween(Page.Text,'<title>',' - '));
  SetField(fieldTranslatedTitle, value);
  value:=ra(TextBetween(Page.Text,'original</strong>:','</'));
  SetField(fieldOriginalTitle, trim(value));
  value:=TextBetween(Page.Text,'amento</strong>:','</');
  SetField(fieldYear, trim(value));
  value:=TextBetween(Page.Text,' </strong> ','</p>');
  value:=TextBetween(value,'(',')');
  SetField(fieldCountry, trim(value));
  value:=TextBetween(Page.Text,'nero</strong>:','</');
  value:=ra(value);
  SetField(fieldCategory, trim(value));
  value:=TextBetween(Page.Text,'dura','/p>');
  value:=ConvertNum(TextBetween(value,'>','<'));
  SetField(fieldLength, trim(value));
  value:=TextBetween(Page.Text,'<strong>produ','/li');
  value:=ra(TextBetween(value,'>:','<'));
  SetField(fieldProducer, FullTrim(value));
  value:=TextBetween(Page.Text,'<li><strong>dire','/li');
  SetField(fieldDirector, trim(value));
  value:=TextBetween(Page.Text,'elenco:','id="ficha_noticias"');
  value:=FormatText2(value);
  SetField(fieldActors, value);
  value:=TextBetween(Page.Text,'sinopse:</h4></div>','</p></div>');
  value:=ra(FormatText2(value));
  SetField(fieldDescription, value);
  value:=TextBetween(Page.Text,'tica do adorocinema</h4>','src="');
  value:=TextBetween(value,'Rate','"');
  SetField(fieldRating, value);
  value:=TextBetween(Page.Text,'thumb" src="','" width=');
  if (value <> '') and CanSetPicture then GetPicture(value);
  GetPicture(value);
procedure AddMoviesTitles(ResultsPage: TStringList);
 Page: string;
 MovieTitle, MovieAddress : String;
 Page := ResultsPage.Text;
 while Pos('>nome original:<', Page) > 0 do
 CutBefore(Page, '>nome original:<');
 MovieAddress := 'http://www.adorocinema.com/filmes' + TextBetween(Page, '<a href="http://www.adorocinema.com/filmes', '/#');
 CutBefore(Page, '<a href="http://www.adorocinema.com/filmes');
 MovieTitle := TextBetween(Page, 'title="', '">');
 MovieTitle := ra(MovieTitle);
 CutAfter(Page, '<span class="favoritos">');
  PickListClear;
  nomeFilme := GetField(fieldTranslatedTitle);
  if (length(nomeFilme)=0) then
    nomeFilme := GetField(fieldOriginalTitle);
  if Input('Importar do Adorocinema', 'Escreve o nome do filme:', nomeFilme) then
    nomeFilme:=stringreplace(nomeFilme,' ','+');
    AnalyzePage('http://www.adorocinema.com/busca/?criteria='+nomeFilme);
Does this replace the version made by Guardião ?
cluis_henrique
antp wrote:Does this replace the version made by Guardião ?
Yes, because the guardião was not working, and not be directly applied to the www.adorocinema.com
Thanks.
I changed the version to 2.0 then, to distinguish it from the old script.
Sorry for late reply, I forgot this topic.
cluis_henrique
New version for the new site structure
Title=AdoroCinema
Language=BR
Version=3.0 (08 Outubro 2011)
Requires=3.5.1
Comments=
Begin
  Result := S;
End;
 Result := S;
s2, ch: string;
    s2 := '';
        s2 := s2 + ch;
    result := s2;
 if Pos('>Titulo Original:<', Page.Text) = 0 then
 Exit;
  value2:=Address;
  //value:=TextBetween(Page.Text,'site oficial</strong>:<a href="','" ');
  //SetField(fieldURL, value + '     (' + value2 + ')' );
  SetField(fieldURL, value2 );
  value:='http://media.'+TextBetween(Page.Text,'<img src="http://media.','"');
  GetPicture(value);
  value:=ra(TextBetween(Page.Text,'class="item fn">','</span>'));
  value:=ra(TextBetween(Page.Text,'original:</strong>','</'));
  value:=TextBetween(Page.Text,'amento:</strong>',' (');
  value:=TextBetween(Page.Text,'amento:</strong>','</p>');
  value:=TextBetween(Page.Text,'Dire','/p>');
  value:=TextBetween(value,'>','<');
  value:=TextBetween(Page.Text,'Atores:','<p><strong>Dura');
  value:=TextBetween(Page.Text,'Dura','/p>');
  value:=TextBetween(Page.Text,'nero:</strong>','</');
  value:=ra(value);
  //value:=TextBetween(Page.Text,'<strong>produ','/li');
  //value:=ra(TextBetween(value,'>:','<'));
  //SetField(fieldProducer, FullTrim(value));
  value:=TextBetween(Page.Text,'"rating nota n','"');
  value:=ConvertNum(value);
  value:=TextBetween(Page.Text,'"description">','</p>');
  value:=TextBetween(Page.Text,'<h2><a href="criticas/"','<div class="criticas-outras">');
  value:=RemoveSpaces(ra(FormatText2(value)),true);
  SetField(fieldComments, value);
  SetField(fieldmediatype, 'DVD');
  // Producer
  Page.Text := GetPage(Address+'ficha-tecnica-e-premios/');
  value:=TextBetween(Page.Text,'dio:</STRONG','<STRONG>dist');
  SetField(fieldProducer, value);
 Page: string;
 while Pos('>Titulo Original:<', Page) > 0 do
 CutBefore(Page, '>Titulo Original:<');
 MovieAddress := 'http://www.adorocinema.com/filmes/' + TextBetween(Page, '<a href="/filmes/', 'comentarios/#f');
 CutBefore(Page, '- </span><a href="/filmes/');
 MovieTitle := TextBetween(Page, 'Titulo Original:</strong> (', ')</p>');
  PickListClear;
thanks
ronniewo2
Post by ronniewo2 »
I finally had some time to rewrite a script that works fine to adorocinema.
Please, comment.
Authors=Ronniewo2 (Ronnie Oliveira)
Title=AdoroCinema
Description=Movie importation script for adorocinema.com
Site=http://adorocinema.com
Language=BR
Version=4.00
Requires=3.5.1
Comments=Shows only 20 first results; only can find whole words (this is a bug of the site)...
var MovieName:string;
uses StringUtils1;
procedure AnalyzeFilmPage(Address:string);
var Page:TStringList;
    valor, Pag, Pag2, Text, valor2:String;
    j, i, min, Code, min2:integer;
  valor:= Address;
  Page.Text:=GetPage(valor);
  SetField(fieldURL,valor);
  SetField(fieldMediaType,'DVD');
  i:=FindLine('<p itemprop="description">',Page,0);
  valor:=Page.GetString(i);
  valor:=TextBetween(Page.Text,'<p itemprop="description">'#13#10,'</p>');
  valor:= Utf8Decode(valor);
  HTMLDecode(valor);
  valor:= StringReplace(valor, '<br/>', #13#10);
  HTMLRemoveTags(valor);
  SetField(fieldDescription, valor);
  i:=FindLine('="og:title" content="',Page,0);
  valor:=TextBetween(valor,'t="','" />');
  HTMLDecode(valor);
  SetField(fieldTranslatedTitle, valor);
  i:=FindLine('<th>Ano de produ',Page,0);
  valor:=TextBetween(valor,'<th>Ano de produ' , '</span></');
  valor:=TextAfter(valor,'">');
  SetField(fieldYear,valor);
  i:=FindLine('original</th><td>',Page,0);
  valor := TextBetween(valor, 'td>' , '</td>');
  HTMLDecode(valor);
  SetField(fieldOriginalTitle, valor);
  Pag:=Page.Text;
  Text:='';
    i:=pos('<span itemprop="genre">',Pag);
    if i>0 then begin
       valor:=copy(Pag,i+20,Length(Pag));
       valor := TextBetween(valor, '">' , '</span>');
       delete(Pag,i,19);
       Text:=Text+' / '+valor;
  until i=0;
  Delete(Text,1,3);
  SetField(fieldCategory,Text);
  i:=FindLine('itemprop="duration"',Page,0);
  valor:=TextBetween(valor,'">','</');
  if copy(valor,2,1)='h' then begin
     Text:=copy(valor,1,1);
     min:=StrToInt(Text,-1);
     if min<>-1 then
        min:=min*60;
  else min:=0;
  Text:=copy(valor,4,1);
  Pag:=copy(valor,5,1);
  if StrToInt(Pag,-1)<>-1 then
     Text:=Text+Pag;
  min2:=StrToInt(Text,-1);
  if min2<>-1 then
     min:=min+min2;
  valor:=IntToStr(min);
  SetField(fieldLength,valor);
  i:=FindLine('itemprop="url" ><span itemprop="name">',Page,0);
  valor := TextBetween(valor, '="name">' , '</span>');
  HTMLDecode(valor);
  SetField(fieldDirector,valor);
  valor:=Page.Text;
  valor := TextBetween(valor, 'Nacionalidade </span>' , #13#10'</div>');
  valor := TextAfter(valor,'<span class="acLnk');
  valor := TextAfter(valor, '">');
  HTMLDecode(valor);
  SetField(fieldCountry,valor);
  i:=FindLine('<meta property="og:image"',Page,0);
  valor:=TextBetween(valor,'"og:image"','/><');
  valor:=TextBetween(valor,'content="','"');
  //*valor:= StringReplace(valor,'195x289','290x478');
  GetPicture(valor);
  valor:= Address+'/creditos';
  Text:='';
  Pag:=TextBetween(Page.Text,'Atores e atrizes','id="production">Topo</span>'#13#10);
  if trim(Pag)='' then
     Pag:=TextBetween(Page.Text,'Atores e atrizes','</table>'#13#10);
    i:=FindLine('Personagem:',Page,0);
    valor:=Page.GetString(i-3);
    valor2:=Page.GetString(i);
    Delete(valor2,pos('Personagem:',valor2),12);
    Page.SetString(i,'nothing important');
    valor:=trim(valor);
    valor:=valor+' - '+valor2;
    valor:= StringReplace(valor, #13#10, ' - ');
    valor:=trim(valor);
    if Length(valor)>1 then
       Text:=Text+#13#10+valor;
  until i=-1;
       i:=pos('<div class="tab_tooltip',Pag);
       valor:=TextBetween(Pag,'<div class="tab_tooltip',#13#10'</span>');//</a>');
       j:=pos('<span itemprop="name">',valor);
       if j>0 then
          valor:=TextAfter(valor,'<span itemprop="name">'#13#10)
       else begin
          valor:=TextAfter(valor,'">'#13#10);
       valor:=trim(valor);
       valor2:=TextBetween(Pag,'<td>'#13#10,#13#10'</td>');
       j:=pos('<td>',Pag);
       Delete(Pag,j,5);
       j:=pos('<td>',Pag);
       Delete(Pag,j,5);
       Delete(Pag,i,23);
       valor:=trim(valor);
  until i=0;
  Text:= Utf8Decode(Text);
  valor:=copy(Text,3,Length(Text));
  SetField(fieldActors,valor);
  Page.free;
procedure AnalyzePage(Address: String);
var Page:string;
    i:integer;
    nome, nome2, ano, url, Pag, Search:string;
  Search:='busca/1/?q='; //1 = filmes
  Page := GetPage(Address+Search+MovieName);
  Pag:=Page;
    i:=pos('"margin-top:-5px;">', Pag);
    url:=copy(Pag,i+30,26);
    url:=TextBetween(url,'/','''');
    nome:=copy(Pag,i+30,pos('<br',Pag));
    nome:=TextBetween(nome,'>'#13#10,'<div>');
    nome:=copy(nome,1,Length(nome)-2);
    nome2:=nome;
    ano:=nome;
    nome:=copy(nome,1,pos(#13#10,nome)-1);
    nome2:=copy(nome2,pos(#13#10,nome2)+2,length(nome2));
    ano:=nome2;
    nome2:=copy(nome2,1,pos(#13#10,nome2)-1);
    ano:=TextBetween(ano,'="fs11">'#13#10,'<br />');
    nome:=nome+' '+nome2+' - '+ano;
    nome:= Utf8Decode(nome);
    HTMLRemoveTags(nome);
    delete(Pag,i,19);
    nome:=trim(nome);
    if (length(nome)>2) and (pos('AdoroCinema',nome)=0) then begin
      url:='http://adorocinema.com/'+url;
      PickTreeAdd(nome,url);
  until i=0;
      AnalyzeFilmPage(Address);
  PickListClear;
  if Input('Importar do AdoroCinema.com', 'Escreva o nome do filme:', MovieName) then
    MovieName := StringReplace(MovieName, ' ', '+');
    AnalyzePage('http://adorocinema.com/');
Is it a complete rewrite from nothing, or did you fix the previous script?
In the latter case, it would be better to also keep the name of previous author
ronniewo2
Post by ronniewo2 »
I rewrote almost 80% of it, and the rest was taken from 2 or 3 other codes. So I didn't feel the needed to include that authors, but, anyway, feel free to include them:
NeiPCs / Guardião / MIKEPAX
And sorry for my mistake...
I'll just include that in the comment then ;)
tiagoaquino
Atualização
Post by tiagoaquino »
A última versão de script q tenho aqui é uma 4.0. Já não funciona com o adorocinema. Alguém atualiza?
ronniewo2
Post by ronniewo2 »
Here you are:
Title=AdoroCinema
Language=BR
Version=5.00
Release date=27/12/16
Requires=3.5.1
Comments=Shows only 20 first results; only can find whole words (this is a bug of the site)...|Previous versions by NeiPCs / Guardião / MIKEPAX
RequiresMovies=1
[Parameters]
uses StringUtils1;
  valor:= Address;
  i:=FindLine('itemprop="aggregateRating"',Page,0);
  valor:=Page.GetString(i+3);
  valor:=TextBetween(valor,' ','</span>');
  HTMLDecode(valor);
  SetField(fieldRating, trim(valor));
  i:=FindLine('itemprop="description">',Page,0);
  valor:=TextBetween(Page.Text,'itemprop="description">','</p>');
  HTMLDecode(valor);
  SetField(fieldDescription, trim(valor));
  HTMLDecode(valor);
  i:=FindLine('">Ano de produ',Page,0);
  valor:=Page.GetString(i+1);
  valor:=TextBetween(valor,'">' , '</span>');
  //valor:=TextAfter(valor,'">');
  i:=FindLine('class="that">',Page,0);
  valor := TextBetween(valor, 'class="that">' , '</span>');
  HTMLDecode(valor);
  Pag:=Page.Text;
  Text:='';
    if i>0 then begin
       delete(Pag,i,19);
  until i=0;
  Delete(Text,1,3);
  i:=FindLine('">Data de lan',Page,0);
  valor:=Page.GetString(i+5);
  valor := trim(valor);
  i:=pos('h',valor);
  min2 := 0;
  if i > 0 then begin
     min2:=StrToInt(copy(valor,i-1,1),-1);
     min:=StrToInt(copy(valor,i+2,2),-1);
     if min2<>-1 then
        min2:=min2*60;
  else min:=0;
  if min2<>-1 then
     min:=min+min2;
  i:=FindLine('itemprop="director"',Page,0);
  HTMLDecode(valor);
  Text := '';
  j:=1;
  i:=FindLine('<span class="light">Nacionalidade',Page,0);
     valor := Page.GetString(i+1);
     if pos('</div>',valor) > 0 then begin
        j := 0;
     else begin
        if valor <> '' then
     i:=i+1;
  until j = 0;
  Delete(Text,1,3);
  valor:= Utf8Decode(Text);
  HTMLDecode(valor);
  SetField(fieldCountry, trim(valor));
  i:=FindLine('class="shot-img"',Page,0);
  valor:=TextBetween(valor,'data-src="','" alt="');
  GetPicture(valor);
  valor:= Address+'creditos/';
  Text:='';
  Pag:=TextBetween(Page.Text,'<div id="actors"','<div class="row md-table-row');
  //if trim(Pag)='' then
     //Pag:=TextBetween(Page.Text,'Atores e atrizes','</table>'#13#10);
    i:=FindLine('Personagem :',Page,0);
    valor:=Page.GetString(i-5);
    Delete(valor2,pos('Personagem :',valor2),13);
    Page.SetString(i,'nothing important'); //exclui a linha de referência já utilizada
    HTMLRemoveTags(valor2);
    valor:=trim(valor)+' ... '+trim(valor2);
    if Length(valor)>5 then
  until i=-1;
       if j>0 then
       else begin
       valor:=trim(valor);
       j:=pos('<td>',Pag);
       Delete(Pag,j,5);
       j:=pos('<td>',Pag);
       Delete(Pag,j,5);
       Delete(Pag,i,23);
       valor:=trim(valor);
  until i=0;
  Page.free;
var Page:string;
    i:integer;
  Pag:=Page;
    url:=copy(Pag,i+30,100);
    nome2:=nome;
    ano:=nome;
    ano:=nome2;
    delete(Pag,i,19);
    nome:=trim(nome);
      url:='http://www.adorocinema.com/'+url;
  until i=0;
  PickListClear;
    AnalyzePage('http://www.adorocinema.com/');
