Scrip for IGN
cluis_henrique
Scrip for IGN
Post by cluis_henrique »
Following the recommendation of ANTP put script ign.com in Mods section. please comment on it.
Authors=(c) 2010 Luis Henrique Carneiro
Title=IGN
Description=Game information import script for IGN
Site=http://www.IGN.com
Language=EN,BR
Version=1.0
Requires=3.5.0
Comments=First public version
License=This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version. |
program IGN;
 StringUtils1;
 GameName: string;
 PageRoot: string;
 ImageFrom: Integer;
// simple string procedures
 while Pos(Old, S) > 0 do
 Result := S;
// Loads and analyses page from internet
 if Pos('NO RESULTS RETURNED FOR', Page.Text) > 0 then
 ShowMessage('Nothing found.');
 Exit;
 PickTreeAdd('Search results:', '');
 AddGamesTitles(Page);
 AnalyzeGamePage(Address);
procedure AnalyzeGamePage(Address: string);
 Page: string;
 PageT: string;
 Value: string;
 Title: string;
 RealTitle: string;
 Review: string;
 Tmp: string;
 Tmp2: string;
 Cover: string;
 Comments: string;
 ReviewLink: string;
 TechLink: string;
 ReqText: string;
 Summary: string;
 Score: string;
 Scores: string;
 ReviewHead: string;
 ReviewAll: string;
 Year: integer;
 isBreak: integer;
 isFirst: integer;
 Page := GetPage(Address);
 tmp  := TextBetween(Page,'score-ign-number','</div>');
 tmp := TextBetween(tmp,'html">','<');
 SetField(fieldRating, tmp);
 tmp := TextBetween(Page,'<div class="column-about-boxart">','<div id="column-about"');
 SetField(fieldDescription, tmp);
 tmp:=TextBetween(Page,'<span class="txt-lbl">Genre:','br/>');
 If (tmp = '') Then tmp := TextBetween(Page,'</span><strong>Genre:','br');
 If (tmp = '') Then tmp := TextBetween(Page,' <strong>Genre: </strong><a','br');
 tmp2 := TextBetween(tmp, '>', '<');
 If (Length(tmp2) < 4) Then tmp2 := TextBetween(tmp, '">', '<');
 SetField(fieldCategory, tmp2);
 tmp:=TextBetween(Page,'>Developer:</span>','br/>');
 If (tmp = '') Then tmp := TextBetween(Page,'>Developed by: <a','/a></');
 tmp := TextBetween(tmp, '>', '<');
 SetField(fieldDirector, tmp);
 tmp:=TextBetween(Page,'"game-title"','span ');
 If (tmp = '') Then tmp := TextBetween(Page,'<title>IGN','/title');
 If (tmp2 = '') Then tmp2 := TextBetween(tmp, ':', '<');
 RealTitle := tmp2;
 SetField(fieldOriginalTitle, RealTitle);
 SetField(fieldTranslatedTitle, RealTitle);
 tmp := TextBetween(Page,'<img id="gameDetailsBoxShotImg"','<br/>');
 If (tmp = '') Then tmp := TextBetween(Page,'<div class="img-thumb"><a href="','</div>');
 cover := TextBetween(tmp, 'src="', '"');
 if cover = '/img/nogame_large.gif' then cover := '';
 if (cover <> '') and CanSetPicture then GetPicture(cover);
 tmp:=TextBetween(Page,'<strong>MSRP: </','br/>');
 SetField(fieldResolution, tmp);
 //*** ESRB rating
  tmp :=TextBetween(Page,'ESRB Rating:','/a>');
  tmp := TextBetween(tmp, '">', '<');
  if tmp <> '' then
  	case tmp of
	  'EC': tmp2 := 'Early Childhood';
    'E': tmp2 := 'Everyone';
    'E10': tmp2 := '10+';
    'T': tmp2 := '13+';
    'M': tmp2 := '17+';
    'AO': tmp2 := '18+';
    'RP': tmp2 := 'Rating Pending';
    else tmp2 := tmp;
  	SetField(fieldCountry, tmp2);
 tmp := TextBetween(Page,'Publisher:</span>','<br/>');
 If (tmp = '') Then tmp := TextBetween(Page,'Published by:','</strong>');
 tmp := TextBetween(tmp, '">', '</a>');
 SetField(fieldProducer, tmp);
 tmp := TextBetween(Page,'"nav-platform"','/span');
 SetField(fieldMediatype, tmp);
 tmp := TextBetween(Page,'<strong>Release Date:</strong>','br/>');
 tmp := TextBetween(tmp,', ','<');
 SetField(fieldYear, trim(copy(tmp, 0, 4)));
 SetField(fieldUrl, Address);
 tmp  := TextBetween(Page,'<div class="nav-lnk"><a href="','" class="nav-content-lnk">');
 If (tmp = '') Then tmp := TextBetween(Page,'<div class="objectNavBtn"><a href="http://cheats.ign.com','">CHEATS<');
 if (tmp <> '') Then tmp := 'http://cheats.ign.com' + tmp;
 Page := GetPage(tmp);
 tmp  := TextBetween(Page,'<h2 class="hdr-section">Cheats & Codes</h2>','<h2 class="hdr-tbl-discuss">');
 HTMLRemoveTags(tmp);
 HTMLDecode(tmp);
 value:=FullTrim(tmp);
 SetField(fieldComments,tmp);
procedure AddGamesTitles(ResultsPage: TStringList);
 Page: string;
 GameTitle, GameAddress , Plat: string;
 Page := ResultsPage.Text;
 while Pos('"searchResultTitle"', Page) > 0 do
 CutBefore(Page, '"searchResultTitle"');
 GameAddress := GetStringFromHTML(Page, '<a ', 'href="', '">', 0);
 Plat:= TextBetween(GameAddress,'http://','.');
 GameTitle := GetStringFromHTML(Page, 'a href', '">', '</a>', 0) + ' (' + Plat + ')';
 //ShowMessage('GA='+GameAddress+#10#13+'GT='+GameTitle);
 CutAfter(Page, '</div>');
 GameAddress := GameAddress;
 PickTreeAdd(GameTitle, GameAddress);
function GetStringFromHTML(Page, StartTag, CutTag, EndTag: string; RemoveTags: Integer): string;
 Result := '';
 CutBefore(Page, StartTag);
 if Length(CutTag) > 0 then
 CutAfter(Page, CutTag);
 // remove html tags (if needed) and decode html string
 if RemoveTags > 0 then
 HTMLRemoveTags(Result);
 HTMLDecode(Result);
//ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
procedure RemovePronoun(var Str: string);
 s: string;
 c: char;
 // remove pronouns
 if (Copy(Str, 0, 2) = 'L ') or (Copy(Str, 0, 2) = 'A ') then
 Str := Copy(Str, 3, Length(Str) - 2)
 else if (Copy(Str, 0, 3) = 'Le ') or (Copy(Str, 0, 3) = 'La ') or (Copy(Str, 0, 3) = 'Un ') then
 Str := Copy(Str, 4, Length(Str) - 3)
 else if (Copy(Str, 0, 4) = 'Les ') or (Copy(Str, 0, 4) = 'Une ') or (Copy(Str, 0, 4) = 'The ') then
 Str := Copy(Str, 5, Length(Str) - 4);
 Str := StringReplaceAll(Str, '_', ' ');
 // remove non-letters, non-digits and non-spaces
 // polish diacritics chars are allowed
 s := '';
 for i := 1 to Length(Str) do begin
 c := StrGet(Str, i);
 if ((c<'a') or (c>'z')) and
 ((c<'A') or (c>'Z')) and
 ((c<'0') or (c>'9')) and
 (c<>' ') and (c<>'a') and
 (c<>'A') and (c<>'e') and
 (c<>'E') and (c<>'c') and
 (c<>'C') and (c<>'s') and
 (c<>'S') and (c<>'z') and
 (c<>'Z') and (c<>'z') and
 (c<>'Z') and (c<>'ó') and
 (c<>'Ó') and (c<>'l') and
 (c<>'L') and (c<>'n') and
 (c<>'N') then
 s := s + Copy(Str, i, 1);
 Str := s;
 if CheckVersion(3,5,0) then begin
 PageRoot := 'http://www.IGN.com';
 GameName := GetField(fieldOriginalTitle);
 if GameName = '' then GameName := GetField(fieldTranslatedTitle);
 RemovePronoun(GameName);
 if Input('IGN.com Import', 'Enter game title:', GameName) then
    Gamename := StringReplaceAll(Gamename, ' ', '%20');
    AnalyzePage('http://search.ign.com/products?query=' + GameName) ;
 end else ShowMessage('AMC version required: 3.5.0');
cluis_henrique
Script IGN for Sisimizi Game Catalog
Sisimizi Game Catalog importation script
http://www.sisimizi.org
Authors=Luis Henrique Carneiro
Title=IGN (multilanguage)
Description=Find and import information about games from ign.com
Site=www.IGN.COM
Language=EN,DE,FR, BR
Version=2.0.0
Requires=1.0.0
Comments=This script is configurable to source your details from any localised version of Amazon and does so over their E-Commerce web services interface. Thus it's not screen scraping and won't be broken by every change that Amazon make.
License="PLEASE KEEP IN MIND THAT SOME OF THE CONTENT THAT WE MAKE AVAILABLE TO YOU THROUGH THIS APPLICATION COMES FROM AMAZON WEB SERVICES. ALL SUCH CONTENT IS PROVIDED TO YOU "AS IS." THIS CONTENT AND YOUR USE OF IT ARE SUBJECT TO CHANGE AND/OR REMOVAL AT ANY TIME."||If you want to support this software and make a donation with no extra costs, you can simply do so by buying something from amazon while using the specific amazon URL, that will be saved on every item - thank you :-)|
program IGN;
 StringUtils1;
 GameName: string;
 PageRoot: string;
 ImageFrom: Integer;
 Result := S;
 Exit;
 Page: string;
 PageT: string;
 Value: string;
 Title: string;
 RealTitle: string;
 Review: string;
 Tmp: string;
 Tmp2: string;
 Cover: string;
 Comments: string;
 ReviewLink: string;
 TechLink: string;
 ReqText: string;
 Summary: string;
 Score: string;
 Scores: string;
 ReviewHead: string;
 ReviewAll: string;
 Year: integer;
 isBreak: integer;
 isFirst: integer;
 SetField(fieldDeveloper, tmp);
 RealTitle := tmp2;
 SetField(fieldCustom1, tmp);
 //*** ESRB rating
  if tmp <> '' then
     case tmp of
    'T': tmp2 := '13+';
    'M': tmp2 := '17+';
    else tmp2 := tmp;
     SetField(fieldclassification, tmp2);
 SetField(fieldPublisher, tmp);
 SetField(fieldPlatform, tmp);
 if (tmp <> '') Then tmp := TextBetween(Page,'<strong><a href="http://cheats.ign.com','#');
 HTMLDecode(tmp);
 SetField(fieldCheats,tmp);
 Page: string;
 Result := '';
 HTMLDecode(Result);
 s: string;
 c: char;
 // remove pronouns
 s := '';
 (c<>'N') then
 Str := s;
 if CheckVersion(1,0,0) then begin
 end else ShowMessage('This script requires a newer version of Sisimizi Game Catalog (at least version 1.0.0)');
Heya, a sisimizi version ! Thanks ! :)
I've uploaded it to sisimizi's scripts server, so that it is available to other users from website and when using the [Update Scripts] script.
