IGN.com Script
cluis_henrique
IGN.com Script
Post by cluis_henrique »
I made a script for IGN.com please test and comment.
http://cid-cc6e2e13b4534630.skydrive.li ... ic/ign.ifs
This is for video games? Maybe it would be good to make a version of the script for Sisimizi Game Catalog, a program made from AMC source code especially for games.
Also note that the "mods" section is maybe better than "scripts" section here, since the latter one is rather for movie-related scripts ;)
cluis_henrique
Yes I agree, except that I prefer to use the AMC to catalog all at the same time, games and movies then this script to do this. The same AMC without Mods.
Okay?
OK, sure, I was just mentionning Sisimizi in case you did not know it ;)
About the "mod", I mean that a script for something else than movie is already a "mod" : when people want to list other things than movies I suggest them to check the "mods" section.
As the script does not use script options it is quite easy to build the sisimizi game catalog version (simply change few fieldnames). I'll probably do that the next days. Thank you so far for your work. :)
