saved files
marix
saved files
Post by marix »
Hi, i have problem. My aamc folder was deleted for some reason and i only noticed that when its gone from recycle bin too. With help of some recovery app (stellar phoenix) i recovered my files. But when i try to open my recovered files i getting error: cannot identify file type from header.
Please its thousands movies i was making 5 years.
You could try to fix the file header with an texteditor like notepad++ by copying and replacing it from an empty catalog, but if the movie data on the file has been damaged it still won't open the file (but maybe partly).
If you can't do it yourself, you need to find an upload possibility and I might have a look on it later (or try sending via mail, but i'm not sure about max. file size then). If you can upload it, you can send link via private message.
