parry
Posts: 15 Joined: 2010-01-12 21:08:34
Post
by parry » 2010-01-12 21:10:56
I was wondering if there was a way to password protect the HTML file taht you create of your movie collection?
The reason I ask is that when I upload it I only want certain people having access to it.
Posts: 9859 Joined: 2002-05-30 10:13:07
Post
by antp » 2010-01-12 22:02:15
On many hosting systems (those running Apache web server) you can password-protect a folder using a .htaccess file. You can easily find help on how to do that on internet by searching with keywords like htaccess password
parry
Post
by parry » 2010-01-13 08:02:52
Sadly mine doesn't, Is there any other way?
Eddie
Posts: 40 Joined: 2005-07-29 07:04:08
Post
by Eddie » 2010-01-13 13:25:58
What kind of webserver are you running? Which hoster?
.htaccess would be the easiest way but you could also use some PHP-scripts.
parry
Post
by parry » 2010-01-13 13:52:06
Its only a free one called hostultra, main reason I went with it is because it supported FTP.
I did make a .htaccess file etc as instructed in an earlier post but when I tried to upload it a file invalid error kept popping up.
Eddie
Post
by Eddie » 2010-01-13 19:11:00
Is that true? YOu have to pay in order to get a MySQL database at that hoster? Well, you will probably find others, also with FTP support, which include mysql and are still for free..
Post
by antp » 2010-01-14 12:49:05
parry wrote: Its only a free one called hostultra, main reason I went with it is because it supported FTP.
Indeed after a quick search on their forum, the free accounts that they provide do not allow htaccess files ...
parry
Post
by parry » 2010-01-14 17:23:40
Is there any other way of doing it other than using a htaccess file?
Post
by antp » 2010-01-17 12:33:39
Yes, using PHP or some other script language if allowed by the server. But it would require some work I think.
