Total Ammount of MB in the Database
Bad Joker
Post by Bad Joker »
hey ant
how can i get the total ammount of all mb in the db?
i want to know that, also, can you add that in the next version as a sql field to the export? and as a html export option??? thx
Somebody already asked it I think, but since Size field is a text field where you can put e.g. "650 + 649" or "650, 649, 700" it would be difficult do use it.
I can try to get the numbers from it and add them, I'll see for next version.
Bad Joker
Post by Bad Joker »
yep i know about the problem, but since i use the "700+500" version, this isn't that hard ;)
maybe i can do it with a script???
i want to test it with the current version, because i want to know if my total size in my sql database is right...
You can do it with a script, you can use the "total discs count" script as basis (I do not remember if it was included with the program, but the script is on the forum) and add the "Size" field parsing.
Bad Joker
Post by Bad Joker »
k i'll try ;)
viewtopic.php?t=315
here is the topic
Bad Joker
Post by Bad Joker »
in your script i don't get where i have to edit that field, didn't found it :(
