For those people not familair with my template please refer to postings of earlier versions in which some explanation is given. In all cases you can ofcourse read the supplied help file.
Version 2.2 introduces the following changes and improvements:
1. Table headers and size have been adjusted to create more 'real estate'
2. Layout files changed to better suite point 1
3. All four colour schemes have been adapted and are better looking
4. Translation of the search field at the top goes now automatic (text is defined in locale.xml)
5. Some clean-up in html files
6. Email submission allows a user to fill in comments before sending the mail
7. Changed the "email" system, which now allows for the traditional mailto (=client) and a submit to a mail processing server (I have included support for the free mail relay service "Response-O-matic")
Points 6 & 7 are specifically for AJW! You may want to try this...
To see the new looks see here
The new zip package can be downloaded from here
Some explanation about Response-O-Matic:
First I am not in any way related to the above company, specific problems I won't answer. That being said; it is very simple to set up!
A. Create a login account at www.response-o-matic.com
B. Follow the three steps to make a new form.
Step 1
-- leave name and email address fields empty and press on proceed to step 2
Step 2
-- check the box "Send them back to your website" and fill in the URL of your website and make a reference to "mailform.html". E.g. www.mywebsite.com/amc/mailform.html. Also make sure you have your correct email address filled in here otherwise you won't receive the user submitted emails!
Step 3
-- in the generated HTML code you find the values of ACCTID and FORMID. These values you need to copy in the account setting located in the file locale.xml. There is no need to keep the HTML code - it is not used at all.
C. In the file locale.xml you need to change the action setting into: "http://www.response-o-matic.com/mail.php" instead of the default "mailto:"
D. Save the locale file and clear your browser cache. From now on mail submission is scripted!
Good luck,
BonieNL
