Un saluto a tutti.Uso l'ultima versione del programma.
Tutti i giochi non funziona più. Cerco di Selezionare la piattaforma ma mi da l'errore non trovato, Quando Nella versione precedente funzionava.Saluti
A greeting for you.Use the latest version of the program.
All Game no longer works. I try to select the platform but it gives me the error Not Found, when in the previous version ok.Tank you
All Game script
First of all, I would like to thank you for this extremely useful and free program
Secondly, I confirm the problem mentioned by paputt.
I checked a little the script and if I am not wrong, it 's trying to locate http://www.allgame.com/cg/agg.dll which seems not to exist any more. Is this the cause of the problem? Is there a workaround?
The Sisimizi Game Catalog version of the script has been updated meanwhile. You can import your Ant Movie Catalog file format easily, as SGC was derived from AMC especially for games.
Allgame script
I modify the Allgame script there's already a long time that seems to works anyway.
Sorry for my English
You can find here
Good catalog
You can find here
Good catalog
