Keep enumeration option
neb1236
Post by neb1236 »
Most of the options in Ant Renamer are saved between sessions, but one isn't.
In the enumeration there is 3 option, "Start At" and "Increment by" are saved, but not "Number of digits".
And because I'm an old school freak I always prefer 001-002-013 over 1-2-13...
I don't know if this is intentional, or a bug.
As an addition, I should recommend making the exact opposite in the saving option, because the "Number of digits" is the less critical one in case of error, the two other option should get back a 1 since they seems to be used very rarely (I may be wrong).
Thank you for Ant, couldn’t leave without it.
It is a bug which was fixed for the next release. If you need it I can send you by e-mail the current "work in progress" version.
I really should finish it and release it "officially".
neb1236
Post by neb1236 »
Fixed before asking, better than perfect, amazing :)
And yes I accept to receive your nightly, if you don't have time, no worry, I can cope without it for several more month
Thank you for the quick reply
ok, I sent it by e-mail ;)
neb1236
Post by neb1236 »
Works just great, thank you very much.
