version Filmaffinity Legrad's (ES) V 1.0
legrad
Post by legrad »
Espero pueda ser de utilidad
un saludo al foro
Authors=Legrad
Title=Filmaffinity Legrad's (ES)
Description=
Site=www.Filmaffinity.com
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
program FilmaffinityLegrads;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
function Caracter(str1: string) :string;
          str1 := StringReplace(str1, 'á' , 'à');
          str1 := StringReplace(str1, 'é' , 'é');
          str1 := StringReplace(str1, 'í',  'í');
          Str1 := StringReplace(Str1, 'ó', 'ó');
          str1 := StringReplace(str1, 'ú' , 'ú');
          str1 := StringReplace(str1, 'ñ' , 'ñ');
          str1 := StringReplace(str1, 'Ã�', 'Á');
          str1 := StringReplace(str1, 'É', 'É');
          str1 := StringReplace(str1, 'Ã�', 'Í');
          str1 := StringReplace(str1, 'Ó', 'Ó');
          str1 := StringReplace(str1, 'Ú', 'Ú');
          str1 := StringReplace(str1, 'Ñ', 'Ñ');
          str1 := StringReplace(str1, 'Â', '');
result := str1;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('resultados.</b></td></tr>', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('<b><a href="/es/film', strPage);
      EndPos := 1;
          EndPos := Pos('.html', strPage);
          MovieId := Copy(strPage,+20, EndPos-20);
          MovieAddr := 'http://www.filmaffinity.com/es/film' + MovieId+'.html';
          BeginPoss := Pos('">',strPage);
          EndPoss := Pos('<img src=', strPage);
          MovieTitle  := TextBetween(MovieTitle , '">', '<');
          MovieTitle := Caracter(MovieTitle);
          DeleteTags(MovieTitle);
          PickTreeSort;
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
  Description := '';
  Comments := '';
  // URL
  // Titulo traducido
  Line := UTF8Encode(Line);
  Item := TextBetween (Line, '<title>', '(');
  HTMLDecode(Item);
  Item := Caracter(Item);
  // Titulo Original
 LineNr := FindLine('<b>TÍTULO ORIGINAL</b></td>', Page, 0);
  if LineNr <> -1 then
    Item := copy(Page.Text, pos('<b>TÍTULO ORIGINAL</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td ><b>', '</b></td>');
    HTMLDecode(Item);
  // año
    Item := TextBetween (Line, '(', ')');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Duracion
   LineNr := FindLine('<b>DURACIÓN</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>DURACIÓN</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr>', 'min.</td>');
    Item := TextBetween (Item, '<td>', 'min');
    HTMLDecode(Item);
  // pais
   LineNr := FindLine('<b>PAÍS</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>PAÍS</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'title="', '"');
    HTMLDecode(Item);
   // director
   LineNr := FindLine('<b>DIRECTOR</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>DIRECTOR</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'href="search.php?stype=director&stext=', '"</td>');
    Item := TextBetween (Item, '">', '</a>');
    HTMLDecode(Item);
  // Reparto
   LineNr := FindLine('<b>REPARTO</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>REPARTO</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'href="search.php?stype=', '</tr>');
    Item := TextBetween (Item, '">', '</a></td>');
    HTMLDecode(Item);
    DeleteTags (Item);
  // productor
   LineNr := FindLine('<b>PRODUCTORA</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>PRODUCTORA</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td  >', '</td>');
    HTMLDecode(Item);
    DeleteTags (Item);
  // Categoria
  LineNr := FindLine('<b>GÉNERO Y CRÍTICA</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>GÉNERO Y CRÍTICA</b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td valign="top">', '/ SINOPSIS:');
    HTMLDecode(Item);
    DeleteTags (Item);
  // sinopsis
    Item := TextBetween (Item, '/ SINOPSIS: ', '(FILMAFFINITY)');
    HTMLDecode(Item);
    DeleteTags (Item);
  // Calificación
  LineNr := FindLine('<tr><td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', Page, 0);
    Item := copy(Page.Text, pos('<tr><td align="center" style="color:#990000; font-size:22px; font-weight: bold;">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<tr><td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', '</td></tr>');
    HTMLDecode(Item);
    DeleteTags (Item);
    SetField(fieldRating, Trim (Item));
   // Guión
LineNr := FindLine('<b>GUIÓN</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>GUIÓN</b></td>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
    DeleteTags (Item);
Comments := Comments + 'Guión: ' + Item +#13#10;
 // fotografia
LineNr := FindLine('<b>FOTOGRAFÍA</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>FOTOGRAFÍA</b>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
    DeleteTags (Item);
Comments := Comments + 'Fotografía: ' + Item +#13#10;
// Musica
LineNr := FindLine('<b>MÚSICA</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>MÚSICA</b>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
    DeleteTags (Item);
Comments := Comments + 'Música: ' + Item +#13#10#13#10;
// Critica
    Item := TextBetween (Item, '--<br />', '--</td>');
    HTMLDecode(Item);
    DeleteTags (Item);
    Item := StringReplace(Item, '-', '');
Comments := Comments + 'CRITICAS: ' + Item +#13#10;
  // Caratula
  LineNr := FindLine('src="/images/enlarge.gif"', Page, 0);
    Item := copy(Page.Text, pos('src="/images/enlarge.gif"',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<a class="lightbox" href="http://pics.filmaffinity.com/', '.jpg');
    HTMLDecode(Item);
    GetPicture ('http://pics.filmaffinity.com/'+Item+'.jpg');
//end;
Input('Filmaffinity', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('Filmaffinity', 'Buscar:', MovieName);
   AnalyzePage('http://www.filmaffinity.com/es/search.php?stext=' + UrlEncode(MovieName)  + '&stype=Title');
azuvk
Post by azuvk »
Gracias por colaborar, ¿qué cambios has hecho?
legrad
Post by legrad »
Verdaderamente no se si se puede decir que son cambios ya que el script esta hecho desde 0 recogiendo toda la imformacion de la pagina mas las criticas, que se añaden al campo comentarios, el tema de las caratulas parece resuelto, parece que la carga de datos es un poco mas rapida o esa es mi impresion. Espero que pueda ser de utilidad
azuvk
Post by azuvk »
No consigo que funcione, con crear un fichero .ifs y pegar el código tendría que valer ¿no? no me encuentra ningun título... :(
de todas formas a ver si me puedes echar una mano. Yo modifico el script original cuando falla algo, pero no entiendo lo suficiente como para crear uno de nuevo, y me gustaría crear uno que importase la información de alguna web de libros o videojuegos (www.bookaffinity.com) por ejemplo.
¿Podrias poner un minitutorial, aunque solo sea para la busqueda inicial en la web y elegir el título correcto? los campos individuales luego ya podría escribir yo el código basándome en los otros scripts.
Un saludo y gracias
legrad
Post by legrad »
Acabo de editar el script de arriba, ahora si funciona vuelvelo a copiar y prueba.
Se ve que cuando lo subi cambio algo de la codificacion de caracteres ahora ya esta resuelto.
Normalmente siempre hago los scripts del mismo tipo, no soy programador aunque a base de observar he podido hacerlos, es un poco complejo explicar como funciona, aunque puedo avanzarte que en los mios es sencillo lo de los campos, en donde radica el quit de la cuestion (observando mis scripts)es en el apartado AnalyzePage y el bloque procedure AnalyzePage(Address: string); si controlas estos dos apartados tienes el 90% de exito, no descarto hacer un pequeño manual de como hago un script de los mios, pero eso sera con mas tiempo.
Si necesitas alguno para alguna web comentamelo puntualizando que informacion recoger
kreti
Post by kreti »
Hola. He estado probando este script, y al importar la imagen, lo hace bien para aquellas que tienen una carátula con mayor resolución, pero falla con aquellas que no la tienen.
Por ejemplo la película Emma 1996, http://www.filmaffinity.com/es/film564665.html, Bugsy 1991, http://www.filmaffinity.com/es/film189062.html, ...
He hecho una modificación sobre el código del script para que capture también la imagen de esas películas que fallan. Creo que ahora incorpora siempre la imagen, al menos con las que probé.
Solo hay que sustituir la parte de carátula para que funcione bien.
  // Caratula
    HTMLDecode(Item);
  if LineNr = -1 then
    LineNr := FindLine('<td align="center"><img src="http://pics.filmaffinity.com', Page, 0);
      Item := copy(Page.Text, pos('<td align="center"><img src="http://pics.filmaffinity.com',Page.Text), length(Page.Text));
      Item := TextBetween (Item, '"http://pics.filmaffinity.com/', '.jpg');
      HTMLDecode(Item);
//end;
[/quote]
