[UA] Hurtom.com
yasia22
[UA] Hurtom.com
Post by yasia22 »
Script for the site http://www.hurtom.com/.
Скрипт для сайту http://www.hurtom.com/.
Authors=yasia22
Title=HurtomCom
Description=Movie importation script for Hurtom.COM forum
Site=www.hurtom.com/torrents/forum/
Language=UA
Version=0.0.3 (2009-11-08)
Requires=3.5.1
Comments=This script is not 100% accurate, as forum users describe movies in many different ways.
License=This program is free software; you can redistribute it and/or modify it under the  terms of the GNU General Public License as published by the Free Software Foundation;  either version 2 of the License, or (at your option) any later version.
Awards=1|1|0=Do not import awards|1=Import awards to Description field, after the summary|2=Import awards to Comments field, after comments
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not ask for movie title, but halts if no movie found
CrewMembers=1|1|0=Don't get any of the crew|1=Get the writer only|2=Get all available
VideoType=3|1|0=[UA] DVD|1=[UA] HD|2=[UA] Movie|3=[UA] Cartoon|4=[UA] Series|5=[UA] Cartoon Series|6=[UA] ArtHouse|7=Movie|8=Cartoon|9=Series|10=Cartoon Series|11=ArtHouse|12=Anime|13=Trailer|14=Subtitled|15=[TV] Music|16=[TV] Documentary|17=[TV] Sport|18=[TV] History|19=[TV] Show
program HurtomCom;
uses StringUtils1;
    MovieName: String;
    MovieURL: String;
    MovieNumber: String;
    isFound: Boolean;
    FoundAddr: String;
    Forums: array of Integer;
// *** Analyze search results page *** //
// *** @input: link to the forum thread of movies/video *** //
// *** @ouput: list of movies *** //
// *** Calls AnalyzeMoviePage() if exact movie found *** //
procedure AnalyzePage(Address: String);
    PageStr, NextPage, MovieAddr, MovieTitle, MovieYear, MovieID: String;
    BeginPos, EndPos: Integer;
    LastPage: Boolean;
    Pages: Integer;
    MovieCount: Integer;
    LastPage := True;
    PageStr := GetPage(Address);
    if (0 < Pos('Сторінка:  <b>1</b>', PageStr)) then
    if (0 < Pos('>наступна</a></span>', PageStr)) then
        LastPage := False;
//        NextPage := TextBetween(PageStr, '</a>  <a href="viewforum.php?f=', '">наступна');
        NextPage := TextBetween(PageStr, '</b>, <a href="viewforum.php?f=', '">');
        NextPage := StringReplace(NextPage, 'amp;', #38);
        NextPage := 'http://www.hurtom.com/torrents/forum/viewforum.php?f=' + NextPage;
    BeginPos := Pos('thCornerR', PageStr);
    if (BeginPos > 0) then
        Delete(PageStr, 1, BeginPos);
        BeginPos := Pos('<td class="row1" width="100%">', PageStr);
        EndPos := 1;
        while ((BeginPos > 0) and (EndPos > 0) and not (isFound)) do
            EndPos := Pos('</td>', PageStr);
            MovieID := TextBetween(PageStr, '?t=', '"');
            MovieAddr := 'http://www.hurtom.com/torrents/forum/viewtopic.php?t=' + MovieID;
            MovieTitle := TextBetween(PageStr, '" class="topictitle">', '</a>');
            HTMLRemoveTags(MovieTitle);
            HTMLDecode(MovieTitle);
            MovieYear := TextBetween(MovieTitle, ' (', ')');
            if 0 < Length(MovieYear) then
                MovieTitle := TextBefore(MovieTitle, ' (', '');
            if (EqualIgnoreCase(MovieName, MovieTitle)) then
                isFound := True;
                FoundAddr := MovieAddr;
            end; // names are equal
            PickTreeAdd(MovieTitle + ' (' + MovieYear + ')', MovieAddr);
            if (Pos('</table>', PageStr) < BeginPos) then
                BeginPos := -1;
        end; // while there are more movies to add
    end; // if there are any search results
    if (LastPage) then
        if (isFound) then
            AnalyzeMoviePage(FoundAddr)
            PickTreeSort;
                AnalyzeMoviePage(Address);
        end; // exact movie title was not found
    end // last page
        AnalyzePage(NextPage);
// *** End of AnalyzePage() *** //
// *** Analyze particular movie page *** //
// *** @input: link to the movie page*** //
// *** @output: parsed values *** //
procedure AnalyzeMoviePage(Address: String);
    PageStr: String;
    Item, Crew: String;
    DescStart: Integer;
    // *  Original title and year* //
    if (CanSetField(fieldOriginalTitle)) then
        Item := GetProperty(PageStr, '<a class="maintitle"', '</td>', '>', '</a>');
        if (0 < Length(TextBetween(Item, ' (', ')'))) then
            SetField(fieldYear, TextBetween(Item, ' (', ')'));
            SetField(fieldOriginalTitle, TextBefore(Item, ' (', ''));
            SetField(fieldMediaType, TextAfter(Item, ') '));
    end; // Original title
    // * Director(s) * //
    if (CanSetField(fieldDirector)) then
        SetField(fieldDirector, GetProperty(PageStr, 'Режисер', '/>', '</span> ', '<br'));
    // *  Studio * //
    if (CanSetField(fieldCountry)) then
        Item := GetProperty(PageStr, 'Кіностудія', '/>', '</span> ', '<br');
        if (0 = Length(Item)) then
            Item := GetProperty(PageStr, 'Країна', '/>', '</span> ', '<br');
        if Pos('Довженка', Item) > 0 then
            Item := 'Довженка';
        SetField(fieldCountry, Item);
    end; // Studio/country added
    // *  Category * //
    if (CanSetField(fieldCategory)) then
        SetField(fieldCategory, GetProperty(PageStr, 'Жанр', '/>', '</span>', '<br'));
    // *  Length * //
    if (CanSetField(fieldLength)) then
        Item := GetProperty(PageStr, 'Тривалість', '/>', '</span>', '<br');
        Item := IntToStr(StrToInt(TextBefore(Item, ':', ''), 0) * 60 + StrToInt(TextBetween(Item, ':', ':'), 0));
        SetField(fieldLength, Item);
    // * URL * //
    if (CanSetField(fieldURL)) then
    // *  Description * //
    if (CanSetField(fieldDescription)) then
        Item := GetProperty(PageStr, 'Сюжет:', 'style="font-weight: bold"', '<span style="font-style: italic">', '</span>');
    end; // Description
    // *  Picture * //
    if (CanSetPicture) then
        ImportPicture(PageStr, '', 'img resizemod="on"', 'border="0"');
    // * Actor(s) * //
    if (CanSetField(fieldActors)) then
        Item := GetProperty(PageStr, 'ролях', '/>', '</span> ', '<br');
            Item := GetProperty(PageStr, 'Актор', '/>', '</span> ', '<br');
        SetField(fieldActors, Item);
    end; // Actor(s) added
    // * Award(s) * //
    Item := GetProperty(PageStr, 'Нагород', 'align="center"', '</span> ', '<div');
    case GetOption('Awards') of
        0:
            Item := '';
        1:
            if (Length(Item) > 0) then
                SetField(fieldDescription, GetField(fieldDescription) + #13#10 + Item);
        2:
                SetField(fieldComments, Item);
    end; // Case awards option
    // * Crew  members: writer(s), operator(s), composer(s), artist(s), sound editor(s) * //
    Crew := '';
    case GetOption('CrewMembers') of
        0: // No crew
            Crew := '';
        end; // case 0
        1: // Writer(s) only
            if (CanSetField(fieldProducer)) then
                Crew := GetProperty(PageStr, 'ценар', '/>', '</span> ', '<br');
                if (0 < Length(Crew)) then
                    Crew := StringReplace(Crew, ', ', ' (сценарист), ') + ' (сценарист)';
                SetField(fieldProducer, Crew);
            end; // Writer(s) found
        end; // case 1
        2: // Whole crew
            if (Pos('ценар', PageStr) > 0) then
                Item := GetProperty(PageStr, 'ценар', '/>', '</span> ', '<br');
                if (0 < Length(Item)) then
                    Item := StringReplace(Item, ', ', ' (сценарист), ') + ' (сценарист)';
                Crew := Item;
            end; // Writer(s)
            if (Pos('Композитор', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Композитор', '/>', '</span>', '<br');
                Item := StringReplace(Item, ', ', ' (композитор), ') + ' (композитор)';
                if (Length(Crew) > 0) then
                    Crew := Crew + ', ';
                Crew := Crew + Item;
            end; // Composer(s)
            if (Pos('Оператор', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Оператор', '/>', '</span>', '<br');
                Item := StringReplace(Item, ', ', ' (оператор), ') + ' (оператор)';
            end; // Operator(s)
            if (Pos('Художник', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Художник', '/>', '</span>', '<br');
                Item := StringReplace(Item, ', ', ' (художник), ') + ' (художник)';
            end; // Artist(s)
            if (Pos('Звуко', PageStr) > 0) then
                Item := GetProperty(PageStr, 'Звуко', '/>', '</span>', '<br');
                Item := StringReplace(Item, ', ', ' (звукорежисер), ') + ' (звукорежисер)';
            end; // SoundEditor(s)
        end; //case 2
    end; // Case crew option
// *** End of AnalyzeMoviePage() *** //
// *** Compare two strings *** //
// *** @input: two strings *** //
// *** @output: boolean comparison result *** //
// *** Ignores case of input strings *** //
function EqualIgnoreCase(String1: string; String2: string): boolean;
    Result := True;
    if (Length(String1) = Length(String2)) then
        String1 := AnsiLowerCase(String1);
        String2 := AnsiLowerCase(String2);
        for i := 0 to Length(String1) do
            if (Copy(String1, i, 1) <> Copy(String2, i, 1)) then
                Result := False;
                Break
        Result := False;
// *** End of EqualIgnoreCase() *** //
// *** Get movie property *** //
// *** @input: string, and two pairs of boundaries*** //
// ***@output: parsed value, stripped of tags *** //
function GetProperty(PageStr: String; Start1: String; End1: String; Start2: String; End2: String): String;
    Item: String;
    Result := '';
    if (Pos(Start1, PageStr) > 0) then
        Item := TextBetween(PageStr, Start1, End1);
        Item := TextBetween(Item, Start2, End2);
        Item := StringReplace(Item, #13#10, '');
        Item := StringReplace(Item, '<br />', #13#10);
        HTMLRemoveTags(Item);
        HTMLDecode(Item);
        Trim(Item);
        Result := Item;
// *** End of GetProperty() *** //
// *** Import a picture *** //
// *** @input: string, base url, and a pair of boundaries*** //
// ***@output: gets a picture *** //
procedure ImportPicture(PageStr: String; BaseURL: String; Start1: String; End1: String);
    Source: String;
    Source := TextBetween(PageStr, Start1, End1);
    if ('' <> Source) then
        if (0 < Pos('src=' + #39, Source)) then
            Source := TextBetween(Source, 'src=' + #39, #39)
        else if (0 < Pos('src="', Source)) then
            Source := BaseURL + TextBetween(Source, 'src="', '"');
        if (Source <> '') then
            GetPicture(Source);
        end; // picture exists
// *** End of ImportPicture() *** //
// *** Main function *** //
Begin
    if (CheckVersion(3,5,1)) then
        //* 0-[UA] DVD
        //* 1-[UA] HD
        //* 2-[UA] Movie
        //* 3-[UA] Cartoon
        //* 4-[UA] Series
        //* 5-[UA] Cartoon Series
        //* 6-[UA] ArtHouse
        //* 7-Movie
        //* 8-Cartoon
        //* 9-Series
        //* 10-Cartoon Series
        //* 11-ArtHouse
        //* 12-Anime
        //* 13-Trailer
        //* 14-Subtitled
        //* 15-[TV] Music
        //* 16-[TV] Documentary
        //* 17-[TV] Sport
        //* 18-[TV] History
        //* 19-[TV] Show
        Forums := [66, 96, 42, 84, 124, 125, 129, 16, 19, 32, 44, 55, 127, 94, 70, 18, 21, 54, 131, 132];
        isFound := False;
        if (('' = MovieName) or ((6 < GetOption('VideoType')) and (15 > GetOption('VideoType')))) then
        if (1 = GetOption('BatchMode')) then
            AnalyzePage('http://www.hurtom.com/torrents/forum/viewforum.php?f=' + IntToStr(Forums[GetOption('VideoType')]))
        else if (Input('Імпорт з Hurtom.Com', 'Назва фільму:', MovieName)) then
            AnalyzePage('http://www.hurtom.com/torrents/forum/viewforum.php?f=' + IntToStr(Forums[GetOption('VideoType')]));
    end // version is fine
        ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.1.1)');
End.
Can you send it to me by e-mail for including with the other scripts? As I can't easily copy/paste it due to the non-European characters.
Thanks.
leviafan
Post by leviafan »
Молодець, так тримати. Дякую.
Для тих хто в танку і не знає як скористатися даним скриптом росказую.
Текст скрипту скопівати і вставити в будь-який текстовий редактор типу блокнота і зберегти скажімо як Hurtom.ifs (ifs це розширення скрипту воно мустить бути обовязково), і помістити файл в папку з скриптами.
Для користувачів лінукса зробити те саме тільки у властивостях файлу поставити галочку навпроти пункту: дозволити виконання файлу як програми.
