FilmAffinity (ES): Fix in movie pictures server url
aviloria
Post by aviloria »
Hi all,
FilmAffinity has changed the url of his movie cover server, and has included a hi-res picture for all of them.
This is the update for the script:
Hola a todos
FilmAffinity ha cambiado la url del servidor de carátulas de las películas, y ha incluido muchas de ellas en una mayor resolución.
La actualización del script es la siguiente:
Authors=aviloria  (aviloria@yahoo.com) modded by: rodpedja (rodpedja@gmail.com), kreti (bisoft@hotmail.com), MrK, gilistico
Title=FilmAffinity (ES)
Language=ES
Version=2.45
Requires=3.5.0
Comments=Updated: Script option for batch running (default disabled), and now it gets the category.
program FilmAffinity;
  BaseURL1 = 'http://www.filmaffinity.com';
  MovieURL: string;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      // quitamos los tabuladores
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   Line,Line2: string;
   Count: Integer;
   Count := 0;
   Page  := TStringList.Create;
   // Veamos si solo hay un solo resultado
   LineNr := FindLine('<b>TITULO ORIGINAL</b>', Page, 0);
   if LineNr <> -1 then
      MovieTitle := TextBetween (Line, '<td ><b>', '</b></td>');
      HTMLDecode(MovieTitle);
      PickTreeAdd(MovieTitle, Address);
       if(GetOption('DontAsk') = 0) then
            if PickTreeExec(Address) then AnalyzeMoviePage(Address);
       if(GetOption('DontAsk') = 1) then AnalyzeMoviePage(Address);
   // Veamos cuantos resultados se han encontrado
   LineNr := FindLine('resultados.</b></td></tr>', Page, 0);
          Count  := StrToInt(TextBetween (Line, '<b>', ' resultados.</b>'), 0);
   // Si no hemos encontrado ningún resultado, abandonamos
       if Count = 0 then
      ShowMessage('No se ha encontrado ningún registro');
   LineNr := 0;
   while TRUE do
      LineNr := FindLine('<b><a href="', Page, LineNr + 1);
      if LineNr = -1 then
         LineNr := FindLine('<b>siguientes >></b>', Page,0);
         if LineNr = -1 then
            break;
              Address   := TextBetween (Line, '<a href="', '">');
         LineNr    := 0;
         continue;
      Line2        := Line;
      MovieAddress := TextBetween (Line, '<b><a href="', '">');
           MovieTitle   := TextBetween (Line2, '.html">', '</td>');
      DeleteTags(MovieTitle);
      if (MovieAddress<>' ') AND (MovieTitle <>'') then
         PickTreeAdd(MovieTitle, BaseURL1 + MovieAddress);
  LineNr, iL, aux, Check: Integer;
  Line,LineAux: string;
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Comments := '';
  Actors := '';
  // URL
  // Translated Title
  LineNr := FindLine('<div style="margin-bottom: 4; padding:1; text-align: left; border-bottom: 1px solid #990000;"><span style="color:#990000; font-size:16; font-weight: bold;">', Page, 0);
  Item := TextBetween (Line, ' border="0"> ', '</span>');
  HTMLDecode(Item);
  // Original Title
  LineNr := FindLine('TITULO ORIGINAL', Page, 0);
    Item := TextBetween (Line, '<td ><b>', '</b></td>');
    HTMLDecode(Item);
  // Picture
  LineNr := FindLine('http://pics2.filmaffinity.com/', Page, 0);
     Item := TextBetween (Line, '<a class="lightbox" href="', '"');
     GetPicture (Item);
  // Year
  LineNr := FindLine('AÑO', Page, 0);
    Item := TextBetween (Line, '<td >', '</td>');
    HTMLDecode(Item);
  // Length
  LineNr := FindLine('DURACIÓN', Page, 0);
    Item := TextBetween (Line, '<td>', ' min.</td>');
    HTMLDecode(Item);
  // Country
  LineNr := FindLine('PAÍS', Page, 0);
    Item := TextBetween (Line, 'title="', '" border');
    HTMLDecode(Item);
  // Director
  LineNr := FindLine('DIRECTOR', Page, 0);
    Directors := '';
    while Pos ('stype=director', Line) > 0 do
      Item := TextBetween (Line, '">', '</a>');
      HTMLDecode(Item);
      if Directors = '' then
        Directors := Item
        Directors := Directors + ', ' + Item;
    SetField(fieldDirector, Trim (Directors));
  // Script writer
  LineNr := FindLine('GUIÓN', Page, 0);
    Comments := Comments + 'Guión: ' + Item + #13#10;
  // Composer
  LineNr := FindLine('MÚSICA', Page, 0);
    Comments := Comments + 'Música: ' + Item + #13#10;
  // Photography
  LineNr := FindLine('FOTOGRAFÍA', Page, 0);
    Comments := Comments + 'Fotografía: ' + Item + #13#10;
  // Actors
  LineNr := FindLine('REPARTO', Page, 0);
   Line := '';
   while TRUE do
      LineNR := LineNR + 1;
      Line   := Line + Page.GetString(LineNr);
      if Pos ('</td>', Line)>0 then
         break;
    Actors := TextBetween (Line, '">', '</a>') + #13#10;
   while Pos ('stype=cast', Line) > 0 do
            Actors := Actors + TextBetween (Line, '"> ', '</a>') + #13#10;
       HTMLDecode(Actors);
       SetField(fieldActors, Actors);
  // Productor
  LineNr := FindLine('PRODUCTORA', Page, 0);
    HTMLDecode(Item);
   // Category
  Check := 0;
  LineNr := FindLine('GÉNERO Y CRÍTICA', Page, 0);
    Line := Page.GetString(LineNr + 6);
    Item := TextBetween (Line, ' / ', ' / ');
   if Length(Item)> 100 then
        Item := TextBetween (Line, '<td valign="top">', ' /');
        if Item <> '' then
          Check := 1;
    HTMLDecode(Item);
  // Critic
    iL := 6;
    Line := Page.GetString(LineNr + iL);
    LineAux := Page.GetString(LineNr + iL+1);
      while  true do
        if Pos('</tr>', LineAux) > 0 then
         break;
          Line := Line+LineAux;
          iL := iL+1;
    HTMLDecode(Line);
    Line := StringReplace(Line, '<br />', #13#10);
    if Check = 1 then
      Item := TextBetween (Line, '/ ', '</td>')
      Item := TextBetween (Line, '<td valign="top">','</td>');
    Item := StringReplace (Item, 'á','á');
    Item := StringReplace (Item, 'é','é');
    Item := StringReplace (Item, 'í','í');
    Item := StringReplace (Item, 'ó','ó');
    Item := StringReplace (Item, 'ú','ú');
    Item := StringReplace (Item, 'Á','Á');
    Item := StringReplace (Item, 'É','É');
    Item := StringReplace (Item, 'Í','Í');
    Item := StringReplace (Item, 'Ó','Ó');
    Item := StringReplace (Item, 'Ú','Ú');
    Item := StringReplace (Item, '"','');
    Item := StringReplace (Item, 'ñ','ñ');
    Item := StringReplace (Item, '¿','¿');
    SetField(fieldDescription, Trim(Item));
  // Official Webpage
  LineNr := FindLine('WEB OFICIAL', Page, 0);
    Comments := Comments + 'Web oficial: ' + TextBetween (Line, '<a href="', '" target="_blank">') + #13#10;
  // Rating
  LineNr := FindLine('<td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', Page, 0);
    Item := TextBetween (Line, '<td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', '</td>');
    HTMLDecode(Item);
    SetField(fieldRating, Item);
  HTMLDecode(Comments);
    AnalyzeMoviePage(MovieName)
    AnalyzePage('http://www.filmaffinity.com/es/search.php?stext=' + UrlEncode(MovieName)  + '&stype=Title');
Thanks.
aas8051
Post by aas8051 »
Thanks for the upgrade.
There are two missing accents in lines 109 and 210 in "TÍTULO ORIGINAL". Add the accent and will get the original title again.
Hola,
Gracias por la actualizacion.
Faltan los acentos en "TÍTULO ORIGINAL" en las líneas 109 y 210. Añadiendolos vuelve a recuperar el título original.
Rgds.
Alberto
aviloria
Post by aviloria »
You are right. Sorry for the inconvenience.
The fixed script is below (version also updated):
Tienes razón. Perdón por las molestias.
El script corregido es el siguiente (también se ha actualizado el número de versión):
Language=ES
Version=2.46
Requires=3.5.0
  MovieURL: string;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
    result := ''
      result := S
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   Line,Line2: string;
   Count: Integer;
   Count := 0;
   LineNr := FindLine('<b>TÍTULO ORIGINAL</b>', Page, 0);
       if Count = 0 then
   LineNr := 0;
   while TRUE do
      if LineNr = -1 then
         if LineNr = -1 then
            break;
         LineNr    := 0;
         continue;
      Line2        := Line;
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Comments := '';
  Actors := '';
  // URL
  // Translated Title
  HTMLDecode(Item);
  // Original Title
  LineNr := FindLine('TÍTULO ORIGINAL', Page, 0);
    HTMLDecode(Item);
  // Picture
     GetPicture (Item);
  // Year
    HTMLDecode(Item);
  // Length
    HTMLDecode(Item);
  // Country
    HTMLDecode(Item);
  // Director
    Directors := '';
      HTMLDecode(Item);
        Directors := Item
  // Script writer
  // Composer
  // Photography
  // Actors
   Line := '';
   while TRUE do
         break;
       HTMLDecode(Actors);
  // Productor
    HTMLDecode(Item);
   // Category
  Check := 0;
        if Item <> '' then
          Check := 1;
    HTMLDecode(Item);
  // Critic
    iL := 6;
      while  true do
         break;
          iL := iL+1;
    HTMLDecode(Line);
    if Check = 1 then
  // Official Webpage
  // Rating
    HTMLDecode(Item);
BittMan
Post by BittMan »
Vuelve a no pillar los carteles... alguien lo puede solucionar?
un saludo y gracias
Don't download the posters again... anyone can fix it?
Thank you and greetings
legrad
Mi version filmaffinity
Post by legrad »
Esta es mi propia version de filmafinity
Authors=Legrad
Title=Filmaffinity Legrad's (ES)
Description=
Site=www.Filmaffinity.com
Language=ES
Version=1.0
Requires=3.5.0
Comments=
License=
program FilmaffinityLegrads;
  MovieURL: string;
function UpFirstLetterWord(texto:string):string;
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
    espaco:=Pos(' ',texto);
    sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then
  texto:=Copy(texto,2,length(texto));
result:=texto;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
function Caracter(str1: string) :string;
          str1 := StringReplace(str1, 'á' , 'à');
          str1 := StringReplace(str1, 'é' , 'é');
          str1 := StringReplace(str1, 'Ã',  'í');
          Str1 := StringReplace(Str1, 'ó', 'ó');
          str1 := StringReplace(str1, 'ú' , 'ú');
          str1 := StringReplace(str1, 'ñ' , 'ñ');
          str1 := StringReplace(str1, 'Ã�', 'Á');
          str1 := StringReplace(str1, 'É', 'É');
          str1 := StringReplace(str1, 'Ã�', 'Í');
          str1 := StringReplace(str1, 'Ó', 'Ó');
          str1 := StringReplace(str1, 'Ú', 'Ú');
          str1 := StringReplace(str1, 'Ñ', 'Ñ');
          str1 := StringReplace(str1, 'Â', '');
result := str1;
    result := ''
      result := S
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  BeginPos, EndPos: Integer;
  BeginPoss, EndPoss: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('resultados.</b></td></tr>', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('<b><a href="/es/film', strPage);
      EndPos := 1;
          EndPos := Pos('.html', strPage);
          MovieId := Copy(strPage,+20, EndPos-20);
          MovieAddr := 'http://www.filmaffinity.com/es/film' + MovieId+'.html';
          BeginPoss := Pos('">',strPage);
          EndPoss := Pos('<img src=', strPage);
          MovieTitle  := TextBetween(MovieTitle , '">', '<');
          MovieTitle := Caracter(MovieTitle);
          PickTreeSort;
           BeginPos := -1;
  Item: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  Busca: integer;
  Description := '';
  Comments := '';
  // URL
  // Titulo traducido
  Line := UTF8Encode(Line);
  Item := TextBetween (Line, '<title>', '(');
  HTMLDecode(Item);
  Item := Caracter(Item);
  // Titulo Original
 LineNr := FindLine('<b>TÍTULO ORIGINAL</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>TÍTULO ORIGINAL</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td ><b>', '</b></td>');
    HTMLDecode(Item);
  // año
    Item := TextBetween (Line, '(', ')');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Duracion
   LineNr := FindLine('<b>DURACIÓN</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>DURACIÓN</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr>', 'min.</td>');
    Item := TextBetween (Item, '<td>', 'min');
    HTMLDecode(Item);
  // pais
   LineNr := FindLine('<b>PAÍS</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>PAÍS</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'title="', '"');
    HTMLDecode(Item);
   // director
   LineNr := FindLine('<b>DIRECTOR</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>DIRECTOR</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'href="search.php?stype=director&stext=', '"</td>');
    Item := TextBetween (Item, '">', '</a>');
    HTMLDecode(Item);
  // Reparto
   LineNr := FindLine('<b>REPARTO</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>REPARTO</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'href="search.php?stype=', '</tr>');
    Item := TextBetween (Item, '">', '</a></td>');
    HTMLDecode(Item);
    DeleteTags (Item);
  // productor
   LineNr := FindLine('<b>PRODUCTORA</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>PRODUCTORA</b></td>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td  >', '</td>');
    HTMLDecode(Item);
    DeleteTags (Item);
  // Categoria
  LineNr := FindLine('<b>GÉNERO Y CRÍTICA</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>GÉNERO Y CRÍTICA</b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<td valign="top">', '/ SINOPSIS:');
    HTMLDecode(Item);
    DeleteTags (Item);
  // sinopsis
    Item := TextBetween (Item, '/ SINOPSIS: ', '(FILMAFFINITY)');
    HTMLDecode(Item);
    DeleteTags (Item);
  // Calificación
  LineNr := FindLine('<tr><td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', Page, 0);
    Item := copy(Page.Text, pos('<tr><td align="center" style="color:#990000; font-size:22px; font-weight: bold;">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<tr><td align="center" style="color:#990000; font-size:22px; font-weight: bold;">', '</td></tr>');
    HTMLDecode(Item);
    DeleteTags (Item);
    SetField(fieldRating, Trim (Item));
   // Guión
LineNr := FindLine('<b>GUIÓN</b></td>', Page, 0);
    Item := copy(Page.Text, pos('<b>GUIÓN</b></td>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
    DeleteTags (Item);
Comments := Comments + 'Guión: ' + Item +#13#10;
 // fotografia
LineNr := FindLine('<b>FOTOGRAFÍA</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>FOTOGRAFÍA</b>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
    DeleteTags (Item);
Comments := Comments + 'Fotografía: ' + Item +#13#10;
// Musica
LineNr := FindLine('<b>MÚSICA</b>', Page, 0);
    Item := copy(Page.Text, pos('<b>MÚSICA</b>',Page.Text), length(Page.Text));
    HTMLDecode(Item);
    DeleteTags (Item);
Comments := Comments + 'Música: ' + Item +#13#10#13#10;
// Critica
    Item := TextBetween (Item, '--<br />', '--</td>');
    HTMLDecode(Item);
    DeleteTags (Item);
    Item := StringReplace(Item, '-', '');
Comments := Comments + 'CRITICAS: ' + Item +#13#10;
  // Caratula
  LineNr := FindLine('src="/images/enlarge.gif"', Page, 0);
    Item := copy(Page.Text, pos('src="/images/enlarge.gif"',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<a class="lightbox" href="http://pics.filmaffinity.com/', '.jpg');
    HTMLDecode(Item);
    GetPicture ('http://pics.filmaffinity.com/'+Item+'.jpg');
//end;
Input('Filmaffinity', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('Filmaffinity', 'Buscar:', MovieName);
What is it compared to the other one? I mean, does it replace it?
legrad
Post by legrad »
Is not necessary, simply another version belongs to filmaffinty, for that he need it.
thank
kreti
Post by kreti »
Para corregir la importación de las carátulas, ir al código del script, y sustituir la parte //Picture por la siguiente:
  // Picture
    HTMLDecode(Item);
  if LineNr = -1 then
    LineNr := FindLine('<td align="center"><img src="http://pics.filmaffinity.com', Page, 0);
      Item := copy(Page.Text, pos('<td align="center"><img src="http://pics.filmaffinity.com',Page.Text), length(Page.Text));
      Item := TextBetween (Item, '"http://pics.filmaffinity.com/', '.jpg');
      HTMLDecode(Item);
Se trata de una modificación del código de Legrad
kreti
Post by kreti »
Otra cosa que falla en el script es que aún cuando la búsqueda solo devuelve un resultado, no importa directamente los datos, sino que te pide que selecciones el título.
Esto se puede corregir fácilmente si en la penúltima línea del script comentamos o borramos el stype=Title de la página de búsquedas.
    AnalyzePage('http://www.filmaffinity.com/es/search.php?stext=' + UrlEncode(MovieName) (* + '&stype=Title'*));
Esto hace que busque también por director o actor, pero pocas veces va a coincidir el título de una película con el nombre de un director o actor.
Otra forma, manteniendo la búsqueda solo en el título es cambiar en el procedure AnalyzePage(Address: string); el siguiente bloque
   LineNr := FindLine('<b>1 resultados.</b>', Page, 0);
      MovieTitle := TextBetween (Line, '.html">', '</a></b>');
BittMan
Post by BittMan »
La modificacion que han puesto para la caratula está bien... pero hay que añadirle una lina más:
sin esto dará error.
Saludos
iosunoenlle
Post by iosunoenlle »
Hello those of filmaffinity changed something of the page, I imagine, since now it does not load the script, so much one as other, the results of genre, synopsis and criticizes, if someone can correct it I would be very grateful, thank you.
crs1122
Post by crs1122 »
Hello everyone. I am new to the forum. I have problems with the script (the last update I have is December 2009). All right until a few days, I do not care or "Class" or the "description", or "cover". Can anyone please could help me?. Thank you. I hit what I have:
Hola a todos. Soy nueva en el foro. Tengo problemas con el script (la última actualización que tengo es de diciembre del 2009. Todo correcto hasta hace unos días, que no me importa ni la "categoría", ni la "descripción", ni la "carátula". ¿Alguien por favor me podría ayudar?. Muchas gracias. Os pego lo que tengo:
MovieURL: string;
Result := -1;
if StartAt < 0 then
StartAt := 0;
Result := i;
result := ''
result := S
c: char;
t: String;
tag := 0;
t := '';
len := length(s);
for n :=1 to len do
c := Copy(s,n,1);
if c = #9 then
c := ' ';
if(tag=1) then
continue;
if(c='<') then
tag := 1;
continue;
t := t + c;
s := t;
result := t;
Line,Line2: string;
Count: Integer;
Count := 0;
if Count = 0 then
LineNr := 0;
while TRUE do
if LineNr = -1 then
if LineNr = -1 then
break;
LineNr := 0;
continue;
Line2 := Line;
Item: string;
Comments: string;
Actors: string;
Directors: string;
Comments := '';
Actors := '';
// URL
// Translated Title
HTMLDecode(Item);
// Original Title
HTMLDecode(Item);
// Picture
GetPicture (Item);
// Year
HTMLDecode(Item);
// Length
HTMLDecode(Item);
// Country
HTMLDecode(Item);
// Director
Directors := '';
HTMLDecode(Item);
Directors := Item
// Script writer
// Composer
// Photography
// Actors
Line := '';
while TRUE do
break;
HTMLDecode(Actors);
// Productor
HTMLDecode(Item);
// Category
Check := 0;
if Item <> '' then
Check := 1;
HTMLDecode(Item);
// Critic
iL := 6;
while true do
break;
iL := iL+1;
HTMLDecode(Line);
if Check = 1 then
// Official Webpage
// Rating
HTMLDecode(Item);
iosunoenlle
For the mask only you have to eliminate 2 of pic and it goes out already for you but I generate that thing about, synopsis and you criticize even not as making it, sure that they changed something on the page of filmaffinity and the script, a greeting was not corrected yet.
Para la caratula solo tienes que eliminar el 2 de pic y ya te sale pero lo de genero, sinopsis y criticas aun no se como hacerlo, seguro que cambiaron algo en la pagina de filmaffinity y todavia no se corrigio el script, un saludo.
iosunoenlle
// Picture
// Picture
LineNr := FindLine('http://pics.filmaffinity.com/', Page, 0);
Asi lo hice yo, pero no se si hay otra forma
crs1122
Post by crs1122 »
Perfecto! Muchísimas gracias por tu ayuda! Ya me carga la carátula.
En cuanto a "género" y "descripción" no encuentro la solución en ningún foro. :(
Perfect! Thank you for your help! I already load the cover.
As for "gender" and "description" I can not find the solution in any forum. : (
masterchipo
No se puede corregir el script de Filmaffinity
Post by masterchipo »
Atento a los cambios en la página de filmaffinity, los cambios recientemente efectuados en los scripts tanto legrad como los anteriores, no funcionan debidamente en los campos: 1ºCATEGORIA, O género, o sea drama, comedia o lo que fuere, 2ºDESCRIPCION, o sea sinópsis, críticas, etc y 3º a veces no funciona ni el año ni la duración
Gracias.
Espero vuestra ayuda.
Ya que el script no serviría de nada.
Ps ¿se podría agregar el script nuevo o modificado en un plantilla para hacer más facil la tarea.
Agradezco desde ya.
masterchipo
klavatelli
Hace un par de días que me trae loco
Post by klavatelli »
Hace un par de días que me trae loco, parece que han cambiado el ítem donde estaba la descripción, que ahora se llama SINOPSIS, antes incluía los Premios y el Género (ahora son categorías aparte) en la primera línea.
masterchipo
Re: Hace un par de días que me trae loco
klavatelli wrote:Hace un par de días que me trae loco, parece que han cambiado el ítem donde estaba la descripción, que ahora se llama SINOPSIS, antes incluía los Premios y el Género (ahora son categorías aparte) en la primera línea.
Claro amigo, eso es lo que intento decir, pero la pregunta es ¿cómo se arregla?
En lo personal cuento: me comuniqué con el staff de Filmaffintiy y me contestaron textualmente, que ellos pueden ayudar, pero no a mí en lo particular sino a los administradores o el staff de Ant.be o Ant Movie Catalog. tema scripts.
Un saludo
iosunoenlle
Intente editar el script variando nombre y cosas elementales y ahora si me detecta los apartados pero sigue sin marcarme la informacion,, pero de ahi no pase, un saludo.
