Page break when printing from web browser
Gurb
Post by Gurb »
Hello all,
First of all, my apologizes if this topic has been already mentioned before, I searched for it within the forums and I couldn't find anything.
My problem is that when I export my catalog to html and try to print my template from a browser, i got the annoying page break anywhere, so most of the times I get half of the data from a film in a page and half of the data in the next page.
I tried to use the 'page-break-inside' html property to avoid breaking into each record, but I couldn't make it work :??:
The alternative is to open my template with Word (for instance) and print it from there, but then I have different problems as Words doesn't deal very well with the size of the tables and it is really a mess the way it displays it.
Any idea or suggestion?
Thanks a lot in advance
Gurb
Post by Gurb »
Hello again,
Didn't anybody have the same problem printing templates? :(
Any help or suggestion please?
Not sure if it's possible here, but could you post the html export code you use on AMC or provide a link to the website you want to print (maybe as PM) ?
PS: Wouldn't be report designer an alternative for printing ?
