update OFDb - IMDb (DE)
gerol
Post by gerol »
you must update OFDb - IMDb (DE)
otherwise you can't get the director(s), country, category, length and language
here is the new version 1.6.0
http://www.file-upload.net/download-201 ... 0.ifs.html
Donald24
Post by Donald24 »
Great!
Thanks Gerol!
Eddie
Post by Eddie »
It is working, but why are some values separated by comma and some by " / "?
Was that done on purpose? I changed it back to ", " but was just curious.
gerol
Post by gerol »
Version 1.6.0 is a major update (therefore increasing the 1.5.x to 1.6.0): For the first time will be scanned for producer, category and country not only the first, but all values. I liked it better to separate the people with a comma and the other categories with a slash.
If that disturbs more than one person, I can use the comma as a separator for all categories with the next update.
gerol
Post by gerol »
to make (almost ;) ) everyone happy:
I improved the script again:
http://www.file-upload.net/download-204 ... 1.ifs.html
The separator (comma or slash) can now be set separately for each value in the options.
There you can also choose whether and where to import aspect ratio, audio format (sound mix) and certification (Altersfreigabe/FSK).
Eddie
Post by Eddie »
great job, thank you!
HiroNakamura
Post by HiroNakamura »
Great Script, thx!
It works really well but it is possible to search für IMDB-ID rather than title? In my case I already have the unique IMBD (like for movie 12 Rounds I have ID "tt1160368") in a field. So theres no movie guessing involved if I would use this information. Right now, your script only takes care of the title and if I select my 200 movies and have to manually select every 3rd movie its really time consuming ;)
So any help what to change in your script would be nice,
Hiro
