Has this program mass importing?
i had to import films once a time writing the film name each time.
IMporting films
Well
When i got this excellent program i type the film name once a time for each film. For importing i select all films and Click import batch but program ask me for film name so i have to retype them (and the name is stored yet!!) . But it isnt a big problem
Another question:
I have a .txt file with 300 films with a no alphabetical order (the number one is my first film a got, number two the second.... etc) . When i import that .txt (only film names) for your program it is in a different order ! (random?)
Do you understand me ? Its important for me because i have stored my films in that order . I can change film number one to one in your program
but .... if i can import in the same order ...
Thanks a lot and sorry for my English
Another question:
antp wrote:Depends of where you want to take the names, you must have movie name somewhere if you do not want to retype them...
You can bypass the title input window by editing the script
e.g. instead of
just leave this:
For the .txt import, that's quite strange that they are not in the same order... can you post a small part of this file if it is possible to reproduce this problem with this small part (e.g. 10 first lines of the file)
e.g. instead of
if Input('IMDb Import', 'Enter the title of the movie:', MovieName) then
AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
sase
IMporting,...
Hi
test.txt :
HACKERS
007 EL MUNDO NUNCA ES SUFICIENTE
ALGO PASA CON MARY
LA TRAMPA
THE FACULTY
PULP FICTION
MATRIX
EL SHOW DE TRUMAN
UNA TERAPIA PELIGROSA
STIGMATA
When i import it, result: result.txt (exporting)
MATRIX
PULP FICTION
EL SHOW DE TRUMAN
STIGMATA
HACKERS
ALGO PASA CON MARY
THE FACULTY
LA TRAMPA
Thanks again
test.txt :
HACKERS
ALGO PASA CON MARY
LA TRAMPA
THE FACULTY
PULP FICTION
MATRIX
EL SHOW DE TRUMAN
STIGMATA
MATRIX
PULP FICTION
EL SHOW DE TRUMAN
STIGMATA
HACKERS
ALGO PASA CON MARY
THE FACULTY
LA TRAMPA
Thanks again
Quite strange, it seems to be a bug in the Sort function of Delphi. Since no number is importer, all movies have number "0". Before assigning new numbers the list is sorted. Since all movies have the same number, they should keep their order.
There is a way to keep the order : put numbers in the list.
You can do that easily with Excel (for example).
Import the txt file, insert a column, put numbers (with the "serie" fill thing it takes one second to do it), then save as to CSV, and import in AMC, using both Number and Title columns.
now txt import is ok but this code doesnt work:
you says AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
but if i have selected for example ten films it doesnt works
If i bypass title input window ....what is the "movieName" valor ?
this variable could be updated for each film ...
antp wrote:You can bypass the title input window by editing the script
e.g. instead ofjust leave this:Code: Select all
if Input('IMDb Import', 'Enter the title of the movie:', MovieName) then begin AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName)); end;For the .txt import, that's quite strange that they are not in the same order... can you post a small part of this file if it is possible to reproduce this problem with this small part (e.g. 10 first lines of the file)Code: Select all
sase
Its all rigth
i have added the line:
and it works like i want
now THANKS AGAIN
this thread is finished
now THANKS AGAIN
Anonymous wrote:Again...
With IMDB works but i am using CULTURALIA script because i am spanish .
Can u give me de code? i supoopse that it is similar to IMDB
