checkboxes unchecked as default
mortenl
Post by mortenl »
I like the Ant Catalogue program very much. But here is a question. I use the optional checkboxes to show which movies I have seen, so I would like the unchecked state to be default. Is this possible ?
Cheers
Morten
There are two ways you can do this. Either add the line
setField(fieldChecked, 'False');
to the script that should set the checkbox unchecked when movie information are downloaded, or open your preferences file prefs.xml (from your Ant Movie Catalog installation folder) with a text editor, search for the DefaultMovie node (values for width and height might differ on your system)
    <DefaultMovie WindowWidth="570" WindowHeight="560">
     <Values Number="0" Checked="True"/>
    </DefaultMovie>
and replace the Checked="True" with Checked="False". This effects general behaviour of AMC and now the checkbox will be unchecked whenever you add a new movie and for any script.
mortenl
Post by mortenl »
Thank you, bad4u, This was just what I needed.
Morten
remyremy
Post by remyremy »
I tried that but the checkbox is still checked when I add a new movie with a script.
I have:
     <Values Number="0" Checked="False"/>
    </DefaultMovie>
But where should I add the following line in my script?
(script: IMBD.ifs)
Thanks!
It should work by changing prefs.xml :??:
At least in versions 3.5.x
If you are using Windows Vista or 7, the prefs.xml file actually used may be in the virtualstore instead of being in program files folder:
go to c:\users\(your name)\appdata\local\virtualstore\program files\...
remyremy
Post by remyremy »
Oups I forgot to precise, I'm using AMC Unofficial 3.8.1
Shouln't be the same?
My folder virtualstore is empty... not even program files folder...
i'm using Win7 and the hidden files/folders are displayed.
Any idea?
Thanks for you help
Post by soulsnake »
</DefaultMovie>
Sorry, this doesn't work with AMC Unofficial 3.8.1 because checkbox is always set to True when a new movie is added :??:.
This is now corrected in AMC Unofficial 3.8.2 ;).
remyremy
Post by remyremy »
Indeed it works now! :)
Merci!
