Could you please add a field for the aspect ratio
galex9
Post by galex9 »
Could you please add a field for the aspect ratio in the Catalog.
I could, but in the meantime you'll have to use one of the existing unused fields for that. Or possibly put it together with the resolution, as it is a free text field.
