[REL] DVD Empire Update
deadeye
Post by deadeye »
* fixed an issue with not returning Title and Media Type after a recent change to the DVD Empire site
Authors=dmitry501,Pavel Uher,Chetan Rao,Deadeye
Title=DVDEmpire.com
Description=Import script for DVD Empire
Site=http://www.dvdempire.com
Language=EN
Version=2.0.10
Requires=3.5.0
Comments=
SearchType=1|1|0=Keyword (more results)|1=Title only (fewer results)
MediaType=0|0|0=DVD|1=Blu-ray|2=HD-DVD
PictureType=0|0|0=Large Picture|1=Small Picture
ClearCheckMark=0|0|0=No|1=Yes
program DVDEmpire;
  StringUtils1;
  extras: string;
function GetValues(Line : String; UseCommaDelimiter : Boolean): String;
    Value     : String;
    StartPos  : Integer;
    EndPos    : Integer;
    Delimiter : String;
  Result := '';
  Line := StringReplace(Line, '•', '');
  if (UseCommaDelimiter) then
    Delimiter := ','
    Delimiter := #13 + #10;
  while(true) do
    StartPos := Pos('">', Line) + 2;
    EndPos := Pos('</a>', Line);
    Value := Copy(Line, StartPos, EndPos - StartPos);
    Line := Copy(Line, EndPos + 1, Length(Line) - EndPos);
    if (EndPos < StartPos) then
      break;
    Value := Trim(Value);
    HTMLDecode(Value);
    HTMLRemoveTags(Value);
    if (Length(Result) > 0) then
      Result := Result + Delimiter;
    Result := Result + Value;
procedure GetInfo(Page: TStringList; ItemID: String);
var Line, Value, Text, TempValue : String;
    LineNR, StartPos, EndPos, LineNrEnd, i, y : Integer;
    LineCR: Boolean;
  // Original Title
  LineNr := FindLine('<td class="fontxlarge"', Page, 0);
  if LineNr > -1 then
    LineNr := LineNr + 1;
    EndPos := Pos('</strong>', Line);
    StartPos := 9;
    Value := Trim(Copy(Line, StartPos, EndPos - StartPos));
  // Media Type
    StartPos := LastPos('"none"', Line) + 8;
    EndPos := Pos('</a></b>', Line);
  // URL
  SetField(fieldURL,'http://www.dvdempire.com/Exec/v4_item.asp?item_id=' + ItemID);
  // Year
  LineNr := FindLine('<b>Production Year:</b>', Page, 0);
  if LineNr > -1 then
    Value := Trim(TextBetween (Line, '<b>Production Year:</b>', ' ') );
    SetField(fieldYear, Value);
  // Length
  LineNr := FindLine('<b>Length:</b>', Page, 0);
  if LineNr > -1 then
    Value := Trim(TextBetween (Line, '<b>Length:</b>', 'mins') );
    SetField(fieldLength, Value);
  //Number of Discs
  LineNr := FindLine('<b>Number of Discs:</b>', Page, 0);
  if LineNr > -1 then
    Value := Trim(TextBetween (Line, '<b>Number of Discs:</b>', '<br />') );
    SetField(fieldDisks, Value);
  // Actors
  LineNr := FindLine('<b>Actors:</b>', Page, 0);
  if LineNr > -1 then
    Line := TextBetween(Line, '<b>Actors:</b>', '</td>');
    Value := GetValues(Line, false);
    SetField(fieldActors, Value);
  // Producers
  LineNr := FindLine('<b>Producers:</b>', Page, 0);
  if LineNr > -1 then
    Line := TextBetween(Line, '<b>Producers:</b>', '<b>Directors:</b>');
    Value := GetValues(Line, true);
  // Directors
  LineNr := FindLine('<b>Directors:</b>', Page, 0);
  if LineNr > -1 then
    Line := TextBetween(Line, '<b>Directors:</b>', '</td>');
  // Picture
  LineNr := FindLine('http://images.dvdempire.com/gen/movies/', Page, 0);
  if LineNr > -1 then
  if GetOption('PictureType') = 1 then
    Line := 'http://images.dvdempire.com/gen/movies/' + ItemID + '.jpg';
    GetPicture(Line);
     Line := 'http://images.dvdempire.com/gen/movies/' + ItemID + 'h.jpg';
     GetPicture(Line);
  // AudioFormat
  LineNr := FindLine('<b>Audio:</b>', Page, 0);
  if LineNr > -1 then
    EndPos := Length(Line) + 1;
    StartPos := LastPos(':', Line) + 1;
    Value := Trim(StringReplace(Value, '[CC]', '') );
    SetField(fieldAudioFormat, Value);
  // Languages
  if LineNr > -1 then
    HTMLRemoveTags(Line);
    Value := TextBetween(Line, 'Audio:', ':');
    Value := AnsiLowerCase(Value);
    Value := AnsiUpFirstLetter(Value);
  //Subtitles
  LineNr := FindLine('<b>Subtitles:</b>', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Line);
    Value := TextAfter(Line, 'Subtitles:');
    SetField(fieldSubtitles, Value);
  // VideoFormat / Resolution
  LineNr := FindLine('<b>Video:</b>', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Line);
    if Pos('Screen Resolution:', Line) > 0 then
      Value := Trim(TextBetween(Line, 'Video:', 'Screen Resolution:') );
      SetField(fieldVideoFormat, Value);
      Value := Trim(TextBetween(Line, 'Screen Resolution:', 'Audio:') );
      SetField(fieldResolution, Value);
      Value := Trim(TextBetween(Line, 'Video:', 'Audio:') );
  // Description
  Value := TextBetween(Page.Text, '<td width="100%" valign="top" class="fontsmall3">', '</table>');
  Value := StringReplace(Value, '>i<', '> <');
  HTMLDecode(Value);
  Value := FullTrim(Value);
  // Rating
  LineNr := FindLine('<b>Rating:</b>', Page, 0);
  if LineNr > -1 then
    Value := 'Rating: ' + Trim(TextBetween(Line, '<b>Rating:</b>', '<br />'));
  // Clear Check Mark
  if GetOption('ClearCheckMark') = 1 then
    SetField(fieldChecked, 'false');
  LineNr, StartPos, EndPos, L, EndPos2: Integer;
  Line, TempValue: string;
  ItemID, MovieAddress, MovieTitle : string;
  AddItem : Boolean;
  LineNr := FindLine('<title>DVD Empire - Item -', Page, 0);
  if LineNr > -1 then
    LineNr := FindLine('javascript:itemHelp(', Page, 0);
    Line := Trim(Page.GetString(LineNr));
    // parameters are separated by ', '
    StartPos := pos(''', ''', Line) + 4; // move past the delimiter
    Line := copy(Line, StartPos, length(Line) - StartPos + 1); // skip the starting quotes
    ItemID := copy(Line, 0, pos(''', ''', Line) - 1);
    GetInfo(Page,ItemID);
    LineNr := FindLine('</strong> Matches Found', Page, 0);
    if LineNr >-1 then
      StartPos := pos('<strong>', Line) + Length('<strong>');
      L := StrToInt('0'+ Copy(Line, StartPos, pos('</strong>', Line) - StartPos),1);
      If L > 50 Then L := 50;
      PickTreeAdd(IntToStr(L)+' Matches found', '');
      If L > 0 Then
        // Find Films
        LineNr := FindLine('<b><a href=''/Exec/v4_item.asp?item_id=', Page, LineNr + 1);
        if LineNr >-1 then
          Line := Trim( Page.GetString(LineNr) );
              // find the item id
              StartPos := Pos('valign=''top''><b><a href=''/Exec/v4_item.asp?item_id=', Line) + 51;
              EndPos := StartPos;
              if (EndPos < 1) then
                break;
                TempValue := Copy(Line, EndPos, 1);
                if (TempValue = '>') then
                  break;
                EndPos := EndPos + 1;
              until(EndPos < 1);
              EndPos := EndPos - 1;
              ItemID := Copy(Line, StartPos, EndPos - StartPos);
              MovieAddress := 'http://www.dvdempire.com/Exec/v4_item.asp?item_id=' + ItemID;
              // discard the stuff we've already processed
              EndPos := EndPos + 2;
              Line   := Copy(Line, EndPos, Length(Line) - EndPos - 1);
              // find the movie name
              StartPos := 1;
              Line := Copy(Line, StartPos, Length(Line) - StartPos);
              MovieTitle := Copy(Line, 1, EndPos - 1);
              // add it to the tree
              HTMLDecode(Movietitle);
              HTMLRemoveTags(MovieTitle);
              L := L - 1;
          until (L = 0);
      ItemID :=copy(Address, 51, 8);
  //DisplayResults;
// Begin program
  if CheckVersion(3,5,0) then
    PickListClear;
    if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
    if Input('Import from www.dvdempire.com', 'Enter the title of the movie:', MovieName) then begin
        MovieName := AnsiLowerCase(MovieName);
        MovieName := StringReplace(MovieName, '’', '');
        MovieName := StringReplace(MovieName, Chr(39), '');
        MovieName := StringReplace(MovieName, ' ', '+');
        // Blu-ray
        if GetOption('MediaType')=1 then extras := '&site_id=69';
        //HD-DVD
        if GetOption('MediaType')=2 then extras := '&site_id=68';
        // SearchType
        if GetOption('SearchType')=1 then extras := extras + '&search_refined=32';
        // &pp=3 limits results to 50
        AnalyzePage('http://www.dvdempire.com/Exec/v5_search_item.asp?string='+MovieName+'&pp=3'+extras);
shitty
Post by shitty »
Works great!
Thanks!
:shit:
Shit
