Some new little scripts requested...
I would like some scripts to make these jobs:
1) Change some or better all fields caps
example: THIS IS THE TITLE >> This it the Title
or something like that
2) Put the actors one for line
I read something about this, but not seen a real script.
Thanks,
Andrea
To change the case, put this between the begin/end of a new script :
SetField(fieldOriginalTitle, AnsiUpFirstLetter(AnsiLowerCase(GetField(fieldOriginalTitle))));
And to remplace linebreaks by commas (for examples) :
SetField(fieldActors, StringReplace(GetField(fieldActors), #13#10, ', '));
Andrea
Post by Andrea »
antp wrote:To change the case, put this between the begin/end of a new script :
I did it - the first give me some "violation address" error, the second seems did nothing...
Andre
That is really not normal
I tryed both before posting and they were woring :/
You used the function Tools -> Scripting ?
I did it...
Did you try it on another movie list or when selecting only few movies ?
I need it because I have more than 1000 movies... if it were less, I did manually :)
I mean, does it happen with all movies or only with some ?
If it is not too big, could you send me your list so I can see if the problem occurs here too ?
(Which version of Windows do you have ?)
frenchfrog_2
Post by frenchfrog_2 »
Hello,
I find out why you got the access violation error, I did some test and you got it when the field is empty, so you have to make sure that the field you want to change is not empty. I modify the script a bit to have the first letter of each words in the fields original title and translated title in caps :
program FindReplaceCaps;
SetField(fieldOriginalTitle, AnsiMixedCase(GetField(fieldOriginalTitle),' '));
SetField(fieldTranslatedTitle, AnsiUpFirstLetter(AnsiLowerCase(GetField(fieldTranslatedTitle))));
SetField(fieldTranslatedTitle, AnsiMixedCase(GetField(fieldTranslatedTitle),' '));
Hope this help...
Ok, if it crashes when the string passed to an Ansi... function, it is a bug, I'll try to correct that :o
