IMDB scripts error
azasap
IMDB scripts error
Post by azasap »
Hi
After last update of IMDB script:
- after searching by name - when saving - couple of read errors and then dialog box with error "ImdbApi failed twice, please retry. If still fails, check your routing to api.imdb.dev"
- after searching by imdb code - everything is ok
thanks
Re: IMDB scripts error
If it is the main IMDb script, it has to be updated.
Cf viewtopic.php?p=93422#p93422
In the meantime the script "IMDb (via API)" should work.
