Bug: Unable to Add Movie – “ImdbApi failed twice” Error
whereisnenad
Post by whereisnenad »
Hi everyone,
I’ve been having trouble adding a new movie in the AMC Catalog app. Every time I try, I get this error message:
ImdbApi failed twice, please retry. If it still fails, check your routing to api.imdbapi.dev.
I’ve already tried reinstalling the app, updating the script and even using a VPN, but the issue persists. It just shows “Bad request” or “Failure” each time.
Has anyone else run into this or found a fix? It's been happening during the last two weeks
Thanks!
Re: Bug: Unable to Add Movie – “ImdbApi failed twice” Error
If it is the main IMDb script, it has to be updated.
Cf viewtopic.php?p=93422#p93422
In the meantime the script "IMDb (via API)" should work.
