How can I change the image size in the Ant Viewer??
Ellie29
Post by Ellie29 »
Hello, when I was looking for a movie organizer I came across a picture of the Ant Viewer where the image in the main window was biiiiig! but when using the program the images imported from the websites when getting the movie info are really small!
Also, I can't find the option to form groups in the side bar at the left... Help!
Thank you, it is the best software I've ever found!
Ellie29
another doubt
Post by Ellie29 »
I forgot to add... in case I can change the image size, what's the size of the big picture??
Thanks!
You are talking about Ant Movie Catalog, not AntViewer or Ant Movie Catalog Viewer (http://www.priyatna.org/antviewer.php), I guess ?
AntViewer is an additional program that shows Ant Movie Catalog files, but cannot organize them or add new movies. It is only there to view your AMC catalog in a nicer way.
For Ant Movie Catalog picture size depends on the specific website and the script you are using for movie import. If the website has large pictures, the script probably imports large pictures, too. Some scripts have an option for changing picture size, if the website offers covers in different sizes, while other scripts import quite small pictures by default. Try another script for larger picture sizes.
If you doubleclick on the picture, it should always show up in original size then.
About groups - it is found on the menu "Tools - Grouping by" (or the little folder tree icon).
Ellie29
Post by Ellie29 »
Yes, I was talking about that!
I'll keep trying different scripts then until I get a bigger picture!
Thanks for your help!
Usually impawards website provides big pictures
Ellie29
Post by Ellie29 »
thank you very much!!!
