Spanish problem
SpiRiTu
Spanish problem
Post by SpiRiTu »
lo ke kiero saber es como hacer para ke el programa califique las peliculas con 5 estrellas en vez de 4 ya tengo mi base en html y gifs para las estrellas del 1 al 10 y no deseo cambiarla. hay alguna forma??
first sorry for my english it's to bad :hum: i want to know how i can do for the program rating the films with 5 stars and don't 4, for the rating be a true rating over 10 i already have a gifs with 1,2,3,4,5,6,7,8,9,10 stars how i can put it? :??:
thanks :cool:
instead of the $$ITEM_APPRECIATION tag (which is only there for compatibility, and that should disappear soon) you can put :
<img src="rating$$ITEM_RATING.gif">
and have gif from rating0.gif to rating10.gif, and also a file rating.gif in the case that the movie has no rating.
SpiRiTu
thank you
Post by SpiRiTu »
thank you very much work perfect ;)
