Erreur de script dans "ALLOCINE_FR" / SCRIPT ERROR
john_lenfr
Post by john_lenfr »
What does mean this error in the script "Allocine":
"Erreur de script dans "ALOCINE_FR": class is not created à la ligne 195"
You have not created TStringList listeResultat, I guess. This should be done on line 1571 (listeResultat := TStringList.Create;).
Download latest Allocine script version from http://update.antp.be/amc/scripts/ or via script "Update Scripts", it should work correct.
john_lenfr
Thanks for your answer.
I'll try to update the script and retry.
The script was not updated recently though :??:
Do you have that with all movies or just one in particular?
