[REL] Allmusic search by "any word" or "exact
As I said some day ago, I give you a script to extract informations from Allmusic.com.
Now you can search by "any word" or "exact expression", just change the option 'Tyoesearch' of the script.
It could be useful to implement the search by artist but I won't have free time in next months and so an help should be useful.....
Here you are the script:
Authors=Fulvio53s03 - based on Frenchfrog2 and sracer works
Title=AllMusic
Description=import artist and/or album
Site=http://www.allmusic.com
Language=EN
Version=1.0
Requires=3.5.0
Comments=this script is based on the script AllGame from Scorpion7552.
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script
author and a link to Ant Movie Catalog  |*  website are given in the About box or in       |*  the documentation of the
program               |
AlbumOpt=2|2|1=search for artist|2=search for album|3=search for song
TypeSearch=1|1|1=search for exact expression|2=search for any word
Mode=0|0|0=normal mode|1=batch mode (url)
// needs the following units
// StringUtils1.pas, StringUtils7552.pas
program AllMusic;
   StringUtils7552;
   AllMusicUrl = 'http://www.allmusic.com';                // base url
   batchlogfic = 'c:\amc_AllGame_batchlog.txt';          // log for batch mode
   debug = false;                                        // debug mode on/off
   debugrep = 'd:\data\disk1\temp';                                // directory where to save files
   Credit_address: String;
   AlbumName, dfltAlbumc, firstcall, abort, name: String;
   Releases, Commento, save_value, indirizzo_pagina, valore_ricerca: String;
   value, sw_serie, StartDelimiter, endDelimiter : string;
   BatchMode, dfltAlbum, Tipo_Ricerca: Integer;
   len_dopo, len_prima, num_char: Integer;
   CharCut, NumChar: integer;
   min_albName, min_alb, dopo, prima: String;
   batchlog, confbatch, memo: TstringList;
   albumok: boolean;
// list of albums or artist
procedure GetList;
   Address, Table, Line, Page, urlmusic, year, album, albumtest, label, genre, Linet: String;
   Relevance: String;
   ValRelev: integer;
   found: boolean;
   i: integer;
   PickTreeClear;                                                    // clear list
   indirizzo_pagina :=  AllMusicUrl+'/cg/amg.dll';
   valore_ricerca := 'sql='+UrlEncode(AlbumName)+'&OPT1='+dfltAlbumc+'&Submit=Go&P=amg';
   found := False;
   PickTreeAdd('List of albums or artists ordered by relevance', '');
   Page := PostPage(indirizzo_pagina, valore_ricerca);
   if debug then
      DumpPage(debugrep+'AllMusicList.txt', Page);                // debug
   if Pos('Album Search Results for:', Page) = 0 then
      LogMessage('Error while reading selection page - no results found');
// selection table
// note: the results are displayed on one page and are sorted by relevance
   Table := TextBetween(Page, '<!--Begin Search Results-->', 'End of List');
   if debug then
         DumpPage(debugrep+'AllMusicListShort.txt', Table);          // debug
   Table := TextAfter(Table, 'Year');
   memo := TStringList.Create;
   memo.Text := StringReplace(Table, '</tr>', crlf);                  // separate lines
   if debug then
      Linet := StringReplace(Table, '</tr>', crlf);
      DumpPage(debugrep+'AllMusicStringList.txt', Linet);             // debug
   urlmusic := 'href="/cg/amg.dll';                               // url to search (first occurence)
   for i := 0 to memo.Count-1 do                                    // list of albums
      Line := memo.GetString(i);                                    // extract current line
      Address := GetUrl(Line, urlmusic, AllMusicUrl);              // get url of album page
      if Address = '' then continue;                                // no url: header or empty line
      Relevance := TextBetween(Line, '<td class="sorted-cell">', 'px;">');
      Relevance := Relevance +  'px;">';
      Relevance := Textbetween(Relevance, 'style="width:', 'px;">');
      Line := TextAfter(Line, '<td class="cell">');
      Line := StringReplace(Line, '</TD>', sepchar1);                // separate fields with </TD>
      year := Trim(TextBefore(Line, sepchar1, ''));                  // year of the album
      Line := RemainingText;
      Line := TextAfter(Line, '>');
      name := TranslateSpecial(Trim(TextBefore(Line, sepchar1, ''))); // name of the artist
      Line := TextAfter(Line, urlmusic);
      albumtest := Trim(TextBefore(Line, 'src', ''));
      if albumtest = '<img' then
      album := TranslateSpecial(Trim(TextBefore(Line, '</a>', '')));  // name of the album
      Line := TextAfter(Line, sepchar1);
      label := Trim(TextBefore(Line, sepchar1, ''));               // label of the album
      genre := Trim(TextBefore(Line, '</a>', ''));                  // genre of the album
// ************** ricerca esatta indipendente da maiuscole, minuscole e spazi ***********
//      if ContainsStr(album, albumName)
      If Tipo_ricerca = 1 then                               // tipo riucerca esatta di albumName
          num_char  := 0;
          CharAbNormal := ' ';
          CharNormal := '';
          min_alb := AnsiLowerCase(album);
          HTMLDecode(min_alb);                                          // Clean description from HTML codes (if some exist)
          HTMLRemoveTags(min_alb);
          min_alb := StringReplace(min_alb, CharAbNormal, CharNormal);
          min_albName := AnsiLowerCase(albumName);
          HTMLDecode(min_albName);                                          // Clean description from HTML codes (if some
exist)
          HTMLRemoveTags(min_albName);
          min_albName := StringReplace(min_albName, CharAbNormal, CharNormal);
          if min_alb = min_albName then
             num_char := 7;                                      // valore non 0
          prima     := TextBefore(min_alb, min_albName, '');
          len_prima := length(prima);
          dopo      := TextAfter(min_alb, min_albName);
          len_dopo  := length(dopo);
          num_char  := num_char + len_prima + len_dopo;
          if num_char > 0 then
//              ValRelev := 100 - StrToInt(Relevance, 0);
//              Relevance := IntToStr(ValRelev);
                Relevance := '';
              PickTreeAdd(Relevance + name+' - '+album+' ('+year+')', Address);
              found := True;
// **********fine ricerca esatta ***********
      If Tipo_ricerca = 2 then                               // tipo riucerca su qualsiasi parola del titolo
          if year <> '' then
//              ValRelev := 100 - StrToInt(Relevance, 2);
                Relevance := '';
              found := True;
   end;         // fine loop    for i := 0 to memo.Count-1 do        // list of albums
   memo.Free;
   if not found then
      LogMessage('No album found for '+AlbumName);
   PickTreeSort;                                                    // sort the list
      Credit_address := Address + '~t2';                           // credits page
      AnalyzeMusicPage(Address);                                    // Album page
      AnalyzeCreditsPage;
      LogMessage('No album selected');
// ANALYZE MUSIC PAGE
procedure AnalyzeMusicPage(Address: string);
   Page, Line, Linet, urlmusic, artisturl, cover, Track, Lenght, Minu, Seco, Pays, usastates: String;
   Autore: String;
   i, TMinu, TSeco: Integer;
   j: Real;
   Page := GetPage(Address);
   if debug then
      DumpPage(debugrep+'AllMusicPageDetail.txt', Page);             // debug
   if Pos('Artist', Page) = 0 then                              // may be this test is OK?
   Begin
      LogMessage('Error while reading album page');
   albumok := True;
//*** artist url
   Value := TextBetween(Page, '<span class="title">', 'class="subtitle');
   artisturl := AllMusicUrl+TranslateSpecial(TextBetween(Value, '<a href="', ' "'));
//*** artist name (=TranslatedTitle)
//*** artist name (=Director) - sracer
   Value := TextBetween(Page, 'class="subtitle">', '</a>');
   SetField(fieldMedia, FormatText(Value));
//*** album title (=originalTitle)
   Value := TextBetween(Page, '<span class="title">', '</span>');
   SetField(fieldTranslatedTitle, FormatText(Value));
//*** rating  (<img src="/img/stars/st_rX.gif"  with X = rating: 1=1 star to 9=5 stars)
// X=1 (1) x=2 (1.5) ... x=9 (5) ==> rating = (x+1) for 0 to 10
   Value := TextBetween(Page, '<img src="/i/pages/site/stars/st_r', '.gif"');
  if Value <> '' then
    i := StrToInt(Value, 0);
    j := (i + 1);                                                     // rating from 0 to 10
// uncomment next line if you want a rating from 0 to 5 (by half point)
//    j := (i + 1) /2;
     SetField(fieldRating, FloatToStr(j));
//*** release date (year only)  ('month year' 'month day, year' or 'year')
   Value := TextBetween(Page, '<span>Release Date</span>', '</table>');
   Value := FormatText(Value);
   i := LastPos(' ', Value);                                          // extract year only
   if i > 0 then Value := Copy(Value, i+1, length(Value));
   SetField(fieldYear, Value);
//*** label (= director)
//   Value := TextBetween(Page,'<span>Label</span>', '</table>');
//   SetField(fieldDirector, FormatText(Value));
//*** type (= country)
   Value := FormatText(TextBetween(Page, '<span>Type</span>', '</table>'));
//   if Value = '' then
//      SetField(fieldCountry,'Standard');
//   if Value <> '' then
//      SetField(fieldCountry, Value);
//   if Value = 'Explicit Lyrics' then
//*** genre (= category)
   Value := TextBetween(Page, '<span>Styles</span>', '</li>');
   SetField(fieldCategory, FormatText(Value));
//*** cover
   cover := TextBetween(Page, '<!--Begin Album Photo-->', '</table>');
   cover := TextBetween(cover, 'img src="', '"');
   if CanSetPicture then
      GetPicture(cover);
//*** album review (= comments)
   Value := FormatText(TextBetween(Page, '<!--Begin Center Content-->', '</table>'));
   Value := TextAfter(Value, 'Reviewby');
   if Value = '' then
      SetField(fieldComments, 'No Review Available');
   if Value <> '' then
      SetField(fieldComments, 'Review by'+Value);
//*** tracks list (= description)
//*** tracks list (= artist) - sracer
   Value := TextBetween(Page, '<!--Begin Center Content-->', '<!--End Center Content-->');
   if debug then
      DumpPage(debugrep+'AllMusicPagetracks.txt', Value);             // debug
   Value := TextAfter(Value, '>Time');
   Value := TextAfter(Value, '</table>');
   Value := TextAfter(Value, '</TD>');
   Value := StringReplace(Value, crlf, '');                     // separate lines
   memo.Text := StringReplace(Value, '</tr>', crlf);                     // separate lines
   if debug then
      Linet := StringReplace(Value, '</tr>', crlf);
      DumpPage(debugrep+'AllMusicPageDetailList.txt', Linet);             // debug
   Value := '';
   Minu := '';
   Seco := '';
   TMinu := 0;
   TSeco := 0;
   for i := 0 to memo.Count-1 do                                       // list of tracks
      Line := TextAfter(Line, '<TD class="cell">');
      Track := Trim(TextBefore(Line, sepchar1, ''));
      if Track <> '' then
         Value := Value+Track;                                       // number of track
// ******************************++ aggiunte qui
         Autore := Line;
//         Autore := textbetween(Autore, '<td class="cell">', '<td align="right" class="cell">');
         Autore := textbetween(Autore, '<TD class="cell">', sepchar1);
         HTMLDecode(Autore);                                          // Clean description from HTML codes (if some exist)
         HTMLRemoveTags(Autore);
//       Value := FullTrim(Autore);                                      // Clean title from HTML tags (if some exist)
         Autore := '  (' + Autore + ')  ';
// fine aggiunte *********************************
         Value := Value+'. '+FormatText(Trim(TextBefore(Line, sepchar1, '')));   // title of track
         Line := TextAfter(Line, sepchar1);                           // not usefull info
         Lenght := FormatText(Trim(TextBefore(Line, sepchar1, '')));         // lenght of track
         Minu := Trim(TextBefore(Lenght, ':', ''));
         Seco := Trim(TextAfter(Lenght, ':'));
         TMinu := TMinu + StrToInt(Minu, 0);                           // extract the minutes
         TSeco := TSeco + StrToInt(Seco, 0);                           // extract the seconds
         if TSeco > 60 then
            TMinu := TMinu + 1;
            TSeco := TSeco - 60;
         Value := Value + autore + ' (' + Lenght + ')';
         Value := Value+crlf;
   Releases := textBetween(Page, '<tr class="visible">', '</table>');
   GetReleases;
   Value := Value + crlf + 'Releases:' + crlf + Releases;
   SetField(fieldActors, Value);
//*** length (only show the minutes)
   if TSeco > 30 then
   TMinu := Tminu + 1;
   SetField(fieldLength, IntToStr(TMinu));
//*** media name (= artist - title) default setting
//   SetField(fieldMedia, GetField(fieldTranslatedTitle)+' - '+GetField(fieldOriginalTitle));
//   SetField(fieldMedia, GetField(fieldDirector)+' - '+GetField(fieldOriginalTitle));
//*** media type (= JewelCase) default setting
//*** media type (= CD) default setting - sracer
   SetField(fieldMediaType, 'CD');
//*** audio format (= VideoFormat = CD) default setting
//   SetField(fieldVideoFormat, 'CD');
//*** source (= AudioFormat = Achat) default setting
   SetField(fieldAudioFormat, 'CD Audio');
//*** number of disks (= VideoBitrate = 1) default setting
//   SetField(fieldVideoBitrate, '1');
//*** country of the artist
   Page := GetPage(artisturl);
   if debug then
      DumpPage(debugrep+'AllMusicArtistDetail.txt', Page);             // debug
   if pos('<!--Begin Formed-->', Page) > 0 then
      Value := TextBetween(Page, '<!--Begin Formed-->', '<!--End Formed-->');
   if pos('<!--Begin Born-->', Page) > 0 then
      Value := TextBetween(Page, '<!--Begin Born-->', '<!--End Born-->');
   if debug then
      DumpPage(debugrep+'AllMusicArtistDetailshort.txt', Value);             // debug
   Value := TextAfter(Value, '<a href=');
   Value := TextBetween(Value, '>', '<');
   Pays := TextAfter(Value, ', ');
//   SetField(fieldSource, Pays);
//   SetField(fieldProducer, 'English');
//   if Pays = 'France' then SetField(fieldProducer, 'French');
//   if Pays = 'Spain' then SetField(fieldProducer, 'Spanish');
//   if Pays = 'Italia' then SetField(fieldProducer, 'Italian');
   usastates :=
'WA,MT,ND,MN,WI,MI,YT,NH,ME,NY,RI,MA,CT,NJ,DE,MD,DC,PA,OH,IN,IL,IA,SD,NE,WY,ID,OR,CA,NV,UT,AZ,CO,NM,KS,OK,TX,MO,AR,LA,KY,TN,M
S,AL,FL,GA,SC,NC,VA,WV,HI,AK';
//   if pos(Pays,usastates) > 0 then
//   begin
//      SetField(fieldSource, 'United States Of America');
//   end;
// &&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&6
procedure GetReleases;
   Riga_Commento, trovato: String;
Begin
   Save_Value := '';
   trovato := 'si';
   Riga_Commento := '* ';
   StartDelimiter := '<TD';
   EndDelimiter   := '</TD>';
      While trovato = 'si' do
      Riga_commento := '';
      trovato := 'no';
      CharCut := Pos(StartDelimiter, Releases);
      Commento := TextBetween(Releases, StartDelimiter, EndDelimiter); // estrae anno
      CharCut := CharCut + length(StartDelimiter) + length(Commento) + length(EndDelimiter);
      delete(Releases, 1, CharCut);
      Commento := StartDelimiter + Commento;
      HTMLRemoveTags(Commento);
      HTMLDecode(Commento);
      Commento := trim(Commento);
      if commento <> '' then
         Riga_Commento := commento + ' ';
         trovato := 'si';
      if commento = '' then
         Riga_Commento := '        ' + ' ';
      Commento := TextBetween(Releases, StartDelimiter, EndDelimiter); // estrae supporto
         Riga_Commento := Riga_Commento + commento + ' - ';
         trovato := 'si';
         Riga_Commento := Riga_Commento + '    ' + ' - ';
         Riga_Commento := Riga_Commento + commento + ' ';
         trovato := 'si';
         Riga_Commento := Riga_Commento + commento;
         trovato := 'si';
      If Trovato = 'si' then
      Save_value := save_value + Riga_commento + crlf;
    Releases := Save_value;
// ANALYZE Credits PAGE
procedure AnalyzeCreditsPage;
   Page, Line, Linet, urlmusic, artisturl, cover, Track, Lenght: String;
   j: Real;
   Page := GetPage(Credit_address);
   NumChar := length(Page);
   if debug then
   if Pos('Credits', Page) = 0 then                              // may be this test is OK?
   Begin
      LogMessage('Error while reading credits page');
//   SetField(fieldURL, Credit_address);
   albumok := True;
//   delete(Page, 1, 11320);
//*** artist url ********************** unuseful?????
//   urlmusic := 'href="/cg/amg.dll';                               // url to search (first occurence)
//   artisturl := AllMusicUrl+TranslateSpecial(TextBetween(Value, '<a href="', ' "'));
// ***************************** estrae i credits (copiato dalle tracce) ***********************************+
//   Value := TextBetween(Page, '<div id="tabcontent_2">', '<div id="tabcontent_3">');
   Value := TextAfter(Page, '<div id="tabcontent_2">');
   NumChar := length(Value);
   Value := TextBefore(Value, '<div id="tabcontent_3">', '');
   Normalizza_Page;
   Getcredits;
// ************************ fine estrae i credits (copiato dalle tracce) ***********************************+
   SetField(fieldDescription, Save_value);
procedure GetCredits;
Begin
   Save_Value := '';
   Commento := '* ';
   While Commento <> '' do
      StartDelimiter := '<td class="sorted-cell';
      CharCut := Pos(StartDelimiter, Value);
      EndDelimiter   := '</td>';
      Commento := TextBetween(Value, StartDelimiter, EndDelimiter); // estrae nome
      delete(Value, 1, CharCut);
      Save_Value := Save_value + commento;
      Save_Value := Save_value + ': ';
      StartDelimiter := '<td class="cell">';
      Commento := TextBetween(Value, StartDelimiter, EndDelimiter); // estrae strumento
         Save_Value := Save_value + commento + ';' + crlf;
    Value := Save_value;
Procedure Normalizza_page;    // elimina i crlf, trasforma delimiters maiuscoli in minuscoli
  CharAbNormal := crlf;
  CharNormal := ' ';
  Value := StringReplace(Value, CharAbNormal, CharNormal);
  CharAbNormal := '<B';
  CharNormal := '<b';
  CharAbNormal := '</B';
  CharNormal := '</b';
//  CharAbNormal := '  ';
//  CharNormal := ' ';
//  Value := StringReplace(Page, CharAbNormal, CharNormal);
  CharAbNormal := '<FONT';
  CharNormal := '<font';
  CharAbNormal := '</FONT';
  CharNormal := '</font';
  CharAbNormal := '<TD';
  CharNormal := '<td';
  CharAbNormal := '</TD';
  CharNormal := '</td';
  CharAbNormal := '<DIV';
  CharNormal := '<div';
  CharAbNormal := '</DIV';
  CharNormal := '</div';
// extract 'various infos'
function ExtrInfo(str1, str2: string) :string;
   str1 := FormatText(TextBetween(str1, str2, '</table>'));
   if str1 <> '' then str1 := crlf+str2+': '+str1;
   result := str1;
   if BatchMode > 0 then
      ShowWarning(m);
   batchlog.Add(m);
   batchlog.SaveToFile(batchlogfic);
// process batch mode
procedure AllMusicBatch;
   AlbumName := GetField(fieldTranslatedTitle);                      // if no url or another site then ignore
   if (AlbumName <> '') and (Pos(AllAlbumUrl, AlbumName) > 0) then
      AnalyzeMusicPage(AlbumName)
      LogMessage('ignored url="'+AlbumName+'"');
// process normal mode
procedure AllMusicNorm;
   albumok := False;
   if dfltAlbum = 1 then
      LogMessage('Sorry this functionality is not operational for now');
//      dfltAlbumc := '1';
//      AlbumName := GetField(fieldTranslatedTitle);        // get artist name
//      repeat
//      if not Input('AllMusic.com Import', 'Enter the name of the artist :', AlbumName) or (AlbumName = '') then exit;
//      GetList;
//      until albumok;
   if dfltAlbum = 2 then
      dfltAlbumc := '2';
      AlbumName := GetField(fieldTranslatedTitle);           // get album name
      if not Input('AllMusic.com Import', 'Enter the name of the album :', AlbumName) or (AlbumName = '') then exit;
      GetList;
      until albumok;
   if dfltAlbum = 3 then
//      dfltAlbumc := '3';
//      AlbumName := GetField(fieldOriginalTitle);           // get song name
//      repeat
//      if not Input('AllMusic.com Import', 'Enter the name of the song :', AlbumName) or (AlbumName = '') then exit;
//      GetList;
//      until albumok;
//  start here
   if abort = 'o' then exit;                                   // batch mode aborted
   if firstcall <> 'done' then
   begin                                                      // 1st call: init parameters
      firstcall := 'done';
      if not CheckVersion(3,5,0) then
         abort := 'o';
      dfltAlbum := GetOption('AlbumOpt');
      Tipo_ricerca := GetOption('TypeSearch');
      if BatchMode > 0 then                                  // batch mode: confirm the choice
         batchlog := TStringList.Create;                     // init batch log
         batchlog.Add('starting batch mode');
         batchlog.Add(StringOfChar('*',80));
// confirmation message
         confbatch := TStringList.Create;
         confbatch.Add('You have selected the batch mode:');
         confbatch.Add('Have you saved your database?');
         confbatch.Add('');
         confbatch.Add('At the end of treatement:');
         confbatch.Add('- look at the file '+batchlogfic+' for errors/infos');
         confbatch.Add('- the albums found will be checked, the others not (for the selection)');
          confbatch.Add(' (see: Tools/Preferences/Movie list/checkboxes)');
         confbatch.Add('');
         confbatch.Add('confirm your choice');
         if not ShowWarning(confbatch.Text) then
           AddToLog('batch mode aborted');                   // batch mode not confirmed = abort
            abort := 'o';
// let's go
   if BatchMode = 0 then
      AllMusicNorm
      AllMusicBatch;
Hope to be useful.... :grinking: [/code]
hariskar
Post by hariskar »
Thank you, but I get this error:
Script error in "MAIN": string error at line 396
Any idea why?
