Thanks everyone.
Finding differences between 2 databases?
I have two almost identical databases: how can I check the differences?
Thanks everyone.
Thanks everyone.
Re: Finding differences between 2 databases?
If you export them to CSV or save as XML you can then easily compare these text files with a file comparer (e.g. with WinMerge or with Notepad++'s compare plugin).
metodo GENIALE nella sua semplicità.
(ovviamente i due archivi devono essere nello stesso ordine....)
proverò.
A brilliant method in its simplicity.
(Obviously, the two archives must be in the same order...).
I'll try.
Thank you!
proverò.
I'll try.
Thank you!
