to order the text within the field
Videomania
Post by Videomania »
It is possible to order the text within the field, example: (Left-Center-Right) Thanks
:p Spain:
Es posible ordenar el texto dentro del campo, ejemplo: (Izquierda-Centro-Derecha)
Gracias
Not really. On scripting you can use some tricks to format the imported data the way you like, but on the GUI it's not possible, I guess. Can you give an example what you think about ?
Videomania
EXAMPLE:
Field Title AMC
(Text) TITANIC (to the left)
Field Title AMC
(Text) TITANIC (to center)
Field Title AMC
(Text) TITANIC (to the right)
This is possible?
I don't think so.
You mean the text in front of the field or the field content itself?
For the text in front you can still cheat by changing its position.
Videomania
