unable to print pictures
Utah
Post by Utah »
Help,
some of my pictures are just printed black.
I tried different sizes, but allways the same result.
Utah
This is usually due to some incompatibility with the printer driver. You can install a virtual PDF printer (PDFCreator, CutePDF, ...), generate a PDF and then print that PDF with Adobe Reader.
