Hi has anyone done a script to get the certification of a movie? I've tried but can't make it work. It would be an easy and fast way to know if a certain movie is apropiate or not for a kid.
I think it could be added to an unoccupied field such as Media Label or Producer, and it could fetch the USA Certification on imdb, since its more global.
Thanks in advance,
Mguel
Script fot imdb Certification?
Finally I managed to make it
Add it on you imdb script. I added the Certification on Borrowers file.
Mguel
//Certificates
LineNr := FindLine('Certification:', Page, 0);
if LineNr > -1 then
BeginPos := pos(';USA:', Line) + 5;
EndPos := pos('">USA:', Line);
HTMLDecode(Value);
SetField(fieldBorrower, Value);
end;Mguel
Ups, forgot to sign in.Anonymous wrote:Finally I managed to make it![]()
Add it on you imdb script. I added the Certification on Borrowers file.Code: Select all
//Certificates LineNr := FindLine('Certification:', Page, 0); if LineNr > -1 then begin Line := Page.GetString(LineNr + 1); BeginPos := pos(';USA:', Line) + 5; EndPos := pos('">USA:', Line); Value := copy(Line, BeginPos, EndPos - BeginPos); HTMLDecode(Value); SetField(fieldBorrower, Value); end;
Mguel
Mguel
Yep that would be the best, but I didn't add it there because of two reasons:antp wrote:I think that I'll add that to the comments field
1.- I don't know programing nor scripting... I made this one based on other fields without much real knowledge of what I was doing
2.- I wanted to be able to export it (html) on a single field next to title/director/actors...
Any way, here is the complete script for adding only the certification to the movies on a catalog (on the borrowers field), in case is usefull for someone
// GETINFO SCRIPTING
// IMDB (US) import USA Certification (on borrowers field)
* Movie importation script for: *
* IMDB (US), http://us.imdb.com *
* (c) 2002 Antoine Potten antoine@buypin.com *
* Improvements made by Danny Falkov *
* Improvements made by Kai Blankenhorn *
* For use with Ant Movie Catalog 3.4.0 *
* www.ant.be.tf/moviecatalog ··· www.buypin.com *
* The source code of the script can be used in *
* another program only if full credits to *
* script author and a link to Ant Movie Catalog *
* website are given in the About box or in *
* the documentation of the program *
program IMDb;
result := -1;
if StartAt < 0 then
StartAt := 0;
result := i;
if pos('<TITLE>IMDb', Page.Text) = 0 then
AnalyzeMoviePage(Page)
LineNr := 0;
LineNr := FindLine('<H2><A NAME="top">Most popular searches</A></H2>', Page, LineNr);
if LineNr > -1 then
PickTreeAdd('Most popular searches', '');
LineNr := FindLine('<H2><A NAME="mov">Movies</A></H2>', Page, LineNr);
if LineNr > -1 then
PickTreeAdd('Movies', '');
LineNr := FindLine('<H2><A NAME="tvm">TV-Movies</A></H2>', Page, LineNr);
if LineNr > -1 then
PickTreeAdd('TV-Movies', '');
LineNr := FindLine('<H2><A NAME="tvs">TV series</A></H2>', Page, LineNr);
if LineNr > -1 then
PickTreeAdd('TV Series', '');
LineNr := FindLine('<H2><A NAME="vid">Made for video</A></H2>', Page, LineNr);
if LineNr > -1 then
PickTreeAdd('Made for video', '');
AnalyzePage(Address);
BeginPos, EndPos: Integer;
//Certification
if LineNr > -1 then
HTMLDecode(Value);
DisplayResults;
procedure GetDescriptions(Address: string);
Line, Value: string;
Page.Text := GetPage('http://us.imdb.com' + Address);
LineNr := FindLine('<p class="plotpar">', Page, 0);
while LineNr > -1 do
Value := '';
if BeginPos > 0 then
BeginPos := BeginPos + 10
BeginPos := 1;
EndPos := pos('</p>', Line);
if EndPos < 1 then
EndPos := Length(Line) + 1;
if Value <> '' then
Value := Value + ' ';
LineNr := LineNr + 1;
until (pos('</p>', Line) > 0) or (LineNr = Page.Count);
PickListAdd(Value);
LineNr := FindLine('<p class="plotpar">', Page, LineNr);
StartPos: Integer;
StartPos := pos('="', Line);
if StartPos > 0 then
Startpos := Startpos + 2;
MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
MovieTitle := copy(Line, StartPos, pos('</A>', Line) - StartPos);
HTMLDecode(Movietitle);
PickTreeAdd(MovieTitle, 'http://us.imdb.com' + MovieAddress);
until pos('</OL>', Line) > 0;
if CheckVersion(3,4,0) then
if Input('IMDb Import', 'Enter the title of the movie:', MovieName) then
// AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName)+'&restrict=Movies+only');
AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
end.Mguel
...me again, here is the script for adding the MPAA description/explanation of the rating of certain movie i.e.:
Rated PG-13 for intense sci-fi action.
or:
Rated R for strong violence/gore, language and some drug content.
Note: This is added on the Producers field
Mguel
or:
//MPAA Rating
LineNr := FindLine('href="/mpaa"', Page, 0);
if LineNr > -1 then
BeginPos := pos('MPAA</a>:', Line) + 14;
EndPos := pos('<br>', Line);
HTMLDecode(Value);
end;Mguel
Yes phpbb forum seems to forget the login quite often, even if it seems well configured
If you want to add info to a field, e.g. comments field, you can do this :
SetField(fieldComments, Value + #13#10 + GetField(fieldComments));
here it adds the contents of Value, followed by a linebreak, then the old contents of the Comments field.
