ItalianMultisite (IT) No actors :(
otreux
Post by otreux »
Ciao :)
I don't know why, but ItalianMultisite doesn't import actors anymore.
I noticed that by changing the value to 0 in the IMBD actors settings (where I think it downloads them), the script works fine, but as soon as I close and reopen the program, the setting reverts to 2 :(
Re: ItalianMultisite (IT) No actors :(
You mean that you change the setting in the IMDb script but run then another script? There is no link between scripts so this seems strange to me :??:
Settings of a script are saved when you run the script.
otreux
Post by otreux »
Maybe I misunderstood, I thought that ItalianMultisite would get some info, like author and poster from IMDb and, in fact, when I stop the script and change the IMDb value and launch ItalianMultisite, the actors are correctly imported
Sorry, it is me who misunderstood your post: I thought you said that you changed a setting in the IMDb script ;)
Indeed ItalianMultisite also uses IMDb site as source of info. Possibly something to check for MrObama2022 then. It is strange that the setting would change its value by itself :??:
