Speed up XLM online Access with database of over 6500 titles
ajwconsult
Post by ajwconsult »
Hello everyone,
Can anyone point me in the right direction on how it would be possible to increase the speed how on fast the xml online database can be loaded.
Example...
There are over 6,500 titles in a database, which has most fields filled in by collecting information with the online databases like imdb.
The XML file is aproximately 4.4Mb in size at the moment.
There is no option to split off the database, as the whole objective is to view, select and search the whole database online.
This is an excellent database program and exports to xml using the online template from this forum.....
Most people don't have a problem with faster connections, but, there are still a few with MODEM connection (i know), which a 4.4Mb file size to load takes a good while.
Thanks in advance for any input.
AJW
