(Es) Filmaffinity, problema con el titulo original
consecuenciactiva
Post by consecuenciactiva »
Buenos dias a todos. Disculpen pero el script de Filmaffinity en español version 2.39 no habilita el campo para "Titulo Original" tampoco recoge la informacion. ¿alguna solucion? Probe cambiando estas lineas:
131 LineNr := FindLine('<b>TÍTULO ORIGINAL</b>', Page, 0);
132 if LineNr = -1 then LineNr := FindLine('<b>TITULO ORIGINAL</b>', Page, 0);
232 LineNr := FindLine('TÍTULO ORIGINAL', Page, 0);
233 if LineNr = -1 then LineNr := FindLine('TITULO ORIGINAL', Page, 0);
y no me ha funcionado. De antemano gracias.
The problem is with the "original title" field that I can not import information from Filmaffinity. Any idea? Thanks.
Simply change TÍTULO ORIGINAL to TITULO ORIGINAL in both lines. Please test for yourself, as I only did a short test with 2 movies.
There is another small change to do, but there is a new script on my server (and through the "update scripts" script)
antp wrote:.., but there is a new script on my server (and through the "update scripts" script)
Even better. And it seems I misunderstood that posting (using online translator) - it was a possible solution, not a question, I guess. Sorry. :)
consecuenciactiva
Thanks to all, problem fixed. I just update the script.
Gracias a todos, se soluciono el problema actualizando el script.
