Filmaffinity 2.39 Rating miss...
Vasniak
Post by Vasniak »
Hi...
I Use the Filmaffinity 2.39 script and I can't get the rating of the movies...
any help?
thanks...
I tested 2.39 with few movies and they all showed up with correct rating.. maybe it's only on specific movies or you imported a movie that had no rating yet ?
zralek
Post by zralek »
You can try adding StringReplace(Item, '.', ',');
before SetField(fieldRating, Item);
I was having that kind of problem with Filmweb (PL) script. Filmaffinity is using 8.1 rating format and AMC 8,1 format (with "," not "."). It is working under XP but from some reason under W7 not. Now I can't get that bug even under W7, but I know that it could be problem.
Maybe its different problem.
Vasniak
Post by Vasniak »
Do not wotk... maybe it's another problem... thanks any way
