WWW.FILMUP.COM ??????
stilegojo
Post by stilegojo »
j'ecrive da l'Italie, et voulez-vous savoir:
Est il possible d'inclure www.filmup.com, dans les script par "Ant movie catalog"?
Merci d'avance
Il suffit que quelqu'un écrive le script pour ce site :D
stilegojo
Post by stilegojo »
Il y a un personne, qu'il fait cette ci?
Grazie
Ork
Post by Ork »
[FR]Je viens de regarder le site. La structure me rappelle celle de Cineguia.
Ca devrait pas être trop long à faire. Je m'y mets tout de suite.
[IT]Ho guardato il sito. Penso che ne sarà lungo fare lo script. Comincio subito.
Ork
Post by Ork »
[FR] Et voilà le script pour FilmUP.
[IT] Ecco lo script per FilmUP.
// GETINFO SCRIPTING
// FilmUP (IT) import
 *      FilmUP (IT), http://www.filmup.com         *
 * (c) 2003 Louis Francisco ork@everydayangels.net *
 *  For use with Ant Movie Catalog 3.4.1           *
program FilmUP;
  TheMovieAddress: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  LineNr: integer;
  BeginPos: integer;
  LineNr := FindLine('<title>FilmUP - Cerca: ', Page, 0);
  if LineNr = -1 then
    AnalyzeMoviePage(Page);
    AddMoviesTitles(Page);
    if TheMovieAddress='' then
  Line, Value: string;
  BeginPos, EndPos: Integer;
  Field: integer;
  LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
  if LineNr > -1 then
    //Translated Title
    HTMLRemoveTags(Line);
      //Look for next info
        LineNr := LineNr + 1;
      until Line<>'';
      //Look for type of line
      if Line = 'Titolo originale: ' then
        Field := fieldOriginalTitle
      else if Line = 'Regia: ' then
        Field := fieldDirector
      else if Line = 'Produzione: ' then
        Field := fieldProducer
      else if Line = 'Nazione: ' then
        Field := fieldCountry
      else if Line = 'Genere: ' then
        Field := fieldCategory
      else if Line = 'Anno: ' then
        Field := fieldYear
      else if Line = 'Durata: ' then
        Field := fieldLength //Special case: get number only
      else if Line = 'Cast: ' then
        Field := fieldActors
      else if Line = 'Trama:' then
        Field := fieldDescription
        Field := 0;
      // I have to add this test, for sometimes the description
      // is on the same line as the tag 'Trama'
      if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
        Field := fieldDescription;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
        //Special case: Length
        if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
      if Field<>0 then SetField(Field,Line);
    until Field=fieldDescription;
  //Rating
  LineNr := FindLine('">Opinioni</a>', Page, LineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('<a href="op_',Line)+8);
    Line := GetLineFromOtherPage('http://www.filmup.com/'+Copy(Line,1,pos('"',Line)-1),'</b> - <img src="/img/star/');
    if Line <> '' then
      SetField(fieldRating,Copy(Line,1,pos('</b> - <img src="/img/star/',Line)-1));
  //Picture
  LineNr := FindLine('<a href="posters/locp/', Page, LineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('<a href="posters/locp/',Line)+8);
    Line := GetLineFromOtherPage('http://www.filmup.com/'+Copy(Line,1,pos('"',Line)-1),'<a href="../loc/500/');
    if Line <> '' then
      Delete(Line,1,pos('<a href="../',Line)+11);
      GetPicture('http://www.filmup.com/posters/'+Copy(Line,1,pos('"',Line)-1), False);
  DisplayResults;
function GetLineFromOtherPage(address: string; hint: string): string;
  LineNr: integer;
  LineNr := FindLine(hint, Page, 0);
  if LineNr > -1 then result := Page.GetString(LineNr);
  TheMovieAddress := '*';
  LineNr := 0;
  LineNr := FindLine('FilmUP - Scheda:',Page,LineNr);
  while LineNr > -1 do
    BeginPos := pos('<a href="',Line)+9;
    EndPos := pos('" TARGET="_blank"><b>FilmUP - Scheda: ',Line);
    MovieAddress := copy(Line,BeginPos,EndPos-BeginPos);
    Delete(Line,1,EndPos);
    BeginPos := pos('Scheda: ',Line)+8;
    EndPos := pos('</a>',Line);
    MovieTitle := copy(Line,BeginPos,EndPos-BeginPos);
    HTMLRemoveTags(MovieTitle);
    HTMLDecode(Movietitle);
    LineNr := FindLine('FilmUP - Scheda:',Page,LineNr+1);
    if TheMovieAddress='*' then
      TheMovieAddress := MovieAddress
      TheMovieAddress := '';
  if CheckVersion(3,4,1) then
    if Input('FilmUP Import', 'Enter the title of the movie:', MovieName) then
      AnalyzePage('http://www.filmup.com/cgi-bin/search.cgi?q='+UrlEncode(MovieName)+'&ul=%25%2Fsc_%25');
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.1)');
Saatchi
Errore
Post by Saatchi »
[IT] Grazie per l'ottimo lavoro, purtroppo lo script mi da il seguente errore: HTTP1.1/ 400 Bad Request
sai come mai?
Grazie.
[FR] Il y a un erreur HTTP1.1/ 400 Bad Request
merci.
Ork
Post by Ork »
[FR] Pour tous les films ? Ou pour un en particulier ? Je pense que c'était un problème temporaire sur le site, parce que ça marche très bien pour moi.
Je viens de m'apercevoir que je n'avais pas importé d'image. Je travaille dessus.
[IT] Per tutte i film ? O per uno specialmente ? Penso che era un problema temporaneo sul sito, perché funziona bene per me.
Mi sono accorto che non ho importato nessun' immagine. Ci lavoro.
Ork
Post by Ork »
[FR] Je viens de modifier le script. Il devrait maintenant importer la note et l'image.
[IT] Ho modificato lo script. Adesso, doverebbe importare il voto e l'immagine.
Valleyman
Post by Valleyman »
[IT] Potresti mettere online il nuovo script che preleva copertina e voto. Quello pubblicato non preleva la cover ed il voto.
Grazie
Valleyman
Post by Valleyman »
[IT] Per l'esattezza lo script su alcuni titoli importa la cover su altri no, stesso vale per le valutazioni.
Esempio:
Blow - cover OK - valutazione NO
Birthday girl - cover NO - valutazione OK
Chocolat - cover OK - valutazione OK
Dungeons & Dragons - cover NO - valutazione NO
Ork
Post by Ork »
pour antp : tu peux effacer mon entrée précédente ? celle inscrite en "guest" ?
[FR] Voici la nouvelle version corrigée pour les photos. Pour la note, le problème vient des demi-points : j'arrondis au-dessus ou en-dessous ? J'ai choisi la valeur inférieur, ça vous va ?
[IT] Ecco la nuova versione corretta per le copertine. Per il voto, il problema viene dai mezzi punti : arrotondo al superiore o al inferiore? Ho scelto la valore inferiore, bene ?
program FilmUP;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  LineNr: integer;
  BeginPos: integer;
  if LineNr = -1 then
  Field: integer;
  if LineNr > -1 then
    //Translated Title
      until Line<>'';
        Field := fieldYear
        Field := 0;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
  //Rating
  if LineNr > -1 then
    if Line <> '' then
      Line := Copy(Line,1,pos('</b> - <img src="/img/star/',Line)-1);
      if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
      SetField(fieldRating,Line);
  //Picture
  if LineNr > -1 then
    Line := GetLineFromOtherPage('http://www.filmup.com/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
    if Line <> '' then
      Delete(Line,1,pos('<img src="../',Line)+12);
  DisplayResults;
  LineNr: integer;
  LineNr := 0;
Ork wrote:pour antp : tu peux effacer mon entrée précédente ? celle inscrite en "guest" ?
ok, c'est fait ;)
stilegojo
Post by stilegojo »
Non so come ringraziare, SIETE I MIGLIORI!
Je Vous remerci beucoup, pour le Votre "Script"!
Vous-etes les Meilleurs!
Excuse-moi pour mon francaise, c'est mauvais!
Stilegojo
Saatchi
Post by Saatchi »
[FR] J ai encore le meme erreur, peut etre un bug du programme, mon OS est Win 98
[IT] Riscontro Ancora lo stesso errore, anche mentre il sito funziona, potrebbe essere un ' incompatibilità del Programma con il mio sistema operativo, uso Windows 98.
Grazie Ciao
La connexion internet utilise-t-elle un proxy ?
Si oui, il faut le configurer dans Tools -> Preferences -> Scripting
saatchi
Post by saatchi »
Non
Ork
Post by Ork »
[FR] Moi aussi j'utilise Windows 98. Peux-tu me dire quelques titres de films pour lesquels ça ne marche pas ?
[IT] Anch'io uso Windows 98. Puoi dirmi alcuni titoli da film per i quali non funziona ?
saatchi
Post by saatchi »
ho praticamente con tutti, comunque ho provato, blow, titanic, chocolat.
Grazie
Ork
Post by Ork »
[FR] Je ne comprends pas pourquoi ça ne marche pas. Je ne reçois aucune erreur. Quelqu'un d'autre a des problèmes avec ce script ?... Est-ce que tu as des erreurs avec d'autres scripts ou seulement le mien ?
[IT] Non capisco perché non funziona. Non ricevo nessun errore. Qualcun altro ha probleme con quello script ?... Hai errori con altri script o solo con il mio ?
Saatchi
Post by Saatchi »
In genere uso solo lo script IMb e ha sempre funzionato, temo sia un problema del mio computer visto che a te ed altri funziona, perciò ho annunciato l'uscita dello script sul forum di quelli che il pc http://www.quellicheilpc.net/, un importante sito italiano dedicato al Divx.
Ciao e Grazie x la disponibilità.
