Error importing/merging from Ant Movie Catalog
I have an AMC catalog and I want to merge it with another.
When I Import, after about 50% of my operation O obtain an error like this:
<picture> Out of Memory....
https://i.postimg.cc/0jV91xrn/Screen-Sh ... 165809.jpg
in Windows 10, 8GB Ram, CPU I37005U, all AMC updated.
My AMC catalog is about 1,400 MB.
what can be?
Re: Error importing/merging from Ant Movie Catalog
Possible that the resulting size of the two catalogs is too big.
AMC is an old 32-bit program, so it is limited to 2 GB of RAM.
One solution is to store pictures externally (in the catalog folder or in a subfolder) instead of having them inside the catalog. Then it would not load all the pictures in memory when loading the catalog (bad design I did 20 years ago :) )
You can change that via Tools -> Manage pictures.
antp wrote: 2025-07-08 06:15:02 Possible that the resulting size of the two catalogs is too big.
... You can change that via Tools -> Manage pictures.
Great! :grinking:
