error with imdb script
cybermcm
Post by cybermcm »
I'm using ANT quiet a long time but today I noticed that I can't add a new movie with the IMDB script.
Script Error in line 401"out of range"
I tried different movies, same result.
I hope someone with programming abilities can help?!?
thx in advance,
CyberMCM
starf
Post by starf »
same here, hope there is an update soon :)
http://www.bad4u.741.com/full/IMDB.ifs (do NOT click, copy link into a NEW browser window !)
I only fixed obvious problems (Director, Producer, Actors), but did no extensive testing. Please give an example movie if there should be other problems I missed or if bugfixes don't work for some movies.
Jorn
Post by Jorn »
works for me:) thnx for the update Bad4u :)
cybermcm
Post by cybermcm »
everything looks fine here too
thx bad4u!!
I changed version number to 3.46, as in the meantime I tried to quickly fix (but probably badly) the script on a mail request - not seeing this message in the forum :D
mica
[FR] IMDB suite
Post by mica »
Bonjour
Et excusez-moi de demander des explications sur la mise à jour du site défaillant imdb : j'ai bien noté le lien
mais je ne sais pas dans quelle fenêtre il faut le mettre ! Pourriez-vous me donner un petit coup de main, car c'est vraiment un site indispensable...
merci d'avance et à bientôt
Mica :??:
You clicked on the link, I guess ?
Please use http://update.antp.be/amc/scripts/IMDB.ifs for download.
mica
[FR] IMDB suite et fin
Post by mica »
Effectivement, je n'avais pas pensé à utiliser UPDATE SCRIPTS ! tout est désormais réparé, et mille fois merci de votre réponse si rapide
:grinking:
