just found a serious bug ... I have saved all covers in the catalog file ... so if you export using "file->export" and as file format "XML" without saving the pictures with the export-file ... all images are removed from the catalog ...
I think the function to save as XML and to export as XML is the same ... but if used for export it "destroys" the catalog-file.
moviecatalog.exe: Version 3.5.1.0 (erstellt am 22.09.2007 11:46:38)
AMCExchange.dll: Version 1.1.0.1 (erstellt am 22.09.2007 11:47:54)
AMCReport.exe: Version 1.0.2.2 (erstellt am 15.01.2005 17:13:56)
MediaInfo.dll: Version 0.7.5.2 (erstellt am 16.08.2007 17:25:18)
You might want to update to latest moviecatalog version. See viewtopic.php?t=3736 for more information about latest updates on 3.5.1.x versions.
Note: If I remember correct, the pictures dissapeared after export to xml, but were lost only if you saved the catalog file then. It was a bug indeed. Thanks.
