Replace Text In List (Custom Field)
TickTock
Post by TickTock »
I have a custom field that is a list of eight different items and I forgot to change the default value when importing lots of new films.
I'm trying to use a script to change the selected films to a different item in the list, but I have no idea how to do this.
I have tried the following:
program CustomChange;
    MovieName := ('Films: Newly Imported');
    SetCustomField ('WatchedUnwatched', MovieName);
Along with everything else I can think of and nothing works. The above code runs, but does nothing. I can copy the default text from the list to a different custom field, but not replace the text in the list. The only information in the help file relating to lists is 'ftList', but I have no idea how to use this to do what I need.
I'm hoping someone can provide some help please.
Re: Replace Text In List (Custom Field)
The syntax is SetCustomField(tagname, newvalue)
So if WatchedUnwatched is the tag of the custom field that you want to change, that line is correct. If the field has a different tag, that may be the reason why it does not work.
For the other line, MovieName := ('Films: Newly Imported'), the parenthesis are not useful here. It is correct if you want to put the text "Films: Newly Imported" in your custom field.
TickTock
Post by TickTock »
Thanks for your response.
The tag name is correct. I created another custom field with the same list and settings, and the above code works :??:
As a test, I then changed the tag of the problematic custom field, ran the code and that didn't work. I even changed the tag to match the newly created custom field (after renaming it) and that also didn't work.
Could a setting cause the value not to be changed with custom lists?
Edit:
I exported my custom fields and opened the file with Notepad++, the custom field I'm having problems with has:
ExcludedInScripts="True"
I removed that, saved the file and imported it back into Ant Movie Catalog and the script ran fine. I then found that setting can be changed
when opening the scripting window in the "Modifiable fields" section. I had unchecked it years ago :lol:
:) I didn't think about that, but it is good that you could solve it then.
